UC560 CUE will not Initialize
aldobson
Hello does anyone know how to initialize CUE in CLI.
We cannot get into CCA passwords in telnet do not match.
Trying to factory reset however CUE will not go offline.
It needs to be initialized.
Please help.
10 Replies 10
paolo bevilacqua
If you search there are a few threads about "service-module session", reset  and re-installation procedure..
We have tried that and either cannot find or not listed regarding re-initualization
If you have a link please provide.
Thanks for replying.
We have tried the factory reset however this is where the problem began.
We cannot take the CUE offline because it has not been initialized.
The message is it has to be online to take offiline.
If it has not initilized yet, just complete that and then configure as required.
As abive you use "service-module session" for that.
Hi Paolo,
That is what I am asking.
How do you complete the initialization.
The above links do not show that.
Need to know step by step process in cli.
Hi Al,
Alternatively you can log into the CUE web browser GUI and initialize it that way, it is the most simplest and easiest way to do it
Log into the browser via the 10.1.10.1 address assuming that you didnt change the service-engine IP address.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
aldobson
Thanks everyone for replying.
Just to let everyone know I did figure it out finally after alot of time.
Just a note was talking to Cisco support and there it created a problem.
If you do not intialize through the Cue the first time you will not have another chance unless you rebuild the CUE.
Talked to support again and they sent me directions how to rebuild because they wanted to RMA the product back.
We needed this so this was not an option at the time.
Had to use boot helper first and then rebuild.
Thanks again!!
You're welcome, please remember to rate useful posts clicking on the stars below.
