05-07-2012 07:15 AM - edited 03-21-2019 05:45 AM
Hello does anyone know how to initialize CUE in CLI.
We cannot get into CCA passwords in telnet do not match.
Trying to factory reset however CUE will not go offline.
It needs to be initialized.
Please help.
05-07-2012 10:16 AM
If you search there are a few threads about "service-module session", reset and re-installation procedure..
05-07-2012 11:14 AM
We have tried that and either cannot find or not listed regarding re-initualization
If you have a link please provide.
Thanks for replying.
05-07-2012 12:05 PM
05-07-2012 12:33 PM
We have tried the factory reset however this is where the problem began.
We cannot take the CUE offline because it has not been initialized.
The message is it has to be online to take offiline.
05-08-2012 05:40 AM
If it has not initilized yet, just complete that and then configure as required.
As abive you use "service-module session" for that.
05-08-2012 05:57 AM
Hi Paolo,
That is what I am asking.
How do you complete the initialization.
The above links do not show that.
Need to know step by step process in cli.
05-13-2012 03:05 AM
05-13-2012 04:15 PM
Hi Al,
Alternatively you can log into the CUE web browser GUI and initialize it that way, it is the most simplest and easiest way to do it
Log into the browser via the 10.1.10.1 address assuming that you didnt change the service-engine IP address.
Cheers,
David.
05-14-2012 06:03 AM
Thanks everyone for replying.
Just to let everyone know I did figure it out finally after alot of time.
Just a note was talking to Cisco support and there it created a problem.
If you do not intialize through the Cue the first time you will not have another chance unless you rebuild the CUE.
Talked to support again and they sent me directions how to rebuild because they wanted to RMA the product back.
We needed this so this was not an option at the time.
Had to use boot helper first and then rebuild.
Thanks again!!
05-17-2012 11:28 PM
You're welcome, please remember to rate useful posts clicking on the stars below.
