01-29-2013 04:05 AM - edited 03-21-2019 09:58 AM
I want to upgrade my SPA112
The manual says to click on administration and then upgrade firmware.
In my administration I have only have "quick setup"
Don't have firmware upgrade.
any idea?
thanks,
JH
Solved! Go to Solution.
01-29-2013 04:26 AM
Hi J, try using different internet browsers. Cycle through such as use IE, Firefox, Chrome, etc.
-Tom
Please mark answered for helpful posts
01-29-2013 04:26 AM
-Tom
01-29-2013 05:11 AM
JH. Make sure you're logging into the GUI as the "admin" username. The "cisco" user has limited privileges. You can alternately upgrade the unit by using CURL and posting a .xml config file telling the unit where to go to upgrade.
01-29-2013 06:31 AM
Hi JH,
As the others have said, first make sure you're logging in as admin. Secondly, if this is a new, never upgraded ATA, you'll have to use Internet Explorer for this first upgrade.
This Firmware Upgrade Process--Explained document and the ones referenced in it may help you:https://supportforums.cisco.com/docs/DOC-29477
Patrick---
Use this reference document to locate SPA ATA resources
01-29-2013 06:44 AM
Hi all,
Thanks!
When I used IE I saw the firmware upgrade.
Thanks again!
Jan
