Voice Systems and Accessories - Small Business
Upgrade your communication system with our Voice Systems and Accessories, perfect for small businesses.
Hi!I can no longer use CCA :-)I tried everything, but when I enter user and password after waiting a few tens of seconds I get the following error window: "Failed to authenticate with the device at ip.ip.ip.ip using TELNET. TELNET access is required ...
Hello everyone, We have SPA112 in our compagny and it works perfectly. 2 days ago we had "no dialtone" issue and I had to fix this ( usually a simple reboot for ATA and all is fine ) But this time figured out that the registration failed every 30 se...
Dear All We have one CISCO SPA3102 and one Cisco PAP2T adapter available at two of our branch offices. Both branches are connected over LAN. We have to configure FXS ports on both branch offices to work as extensions over IP. Kindly let me know if th...
Dear All, I need your help in setting up SPA3102 with CUCM so SPA3102 can be used to make calls from IP phones (registered with CUCM) to PSTN numbers. I was struggling to make it work for many days but still not finding the clue where i am going wron...
faswar.mon by Beginner
  • 3546 Views
  • 4 replies
Hi!  I have been playing around with my setup for a while now, finally have everything working the way i want to.. except... i found out today that when i am out of office i divert my call to my mobile number.  Now the call will actually ring throu...
andrewr87 by Beginner
  • 414 Views
  • 0 replies
