Upgrade SPA112
j.huizinga
Level 6
Level 6
I want to upgrade my SPA112
The manual says to click on administration and then upgrade firmware.
In my administration I have only have "quick setup"
Don't have firmware upgrade.
any idea?
thanks,
JH
Tom Watts
Hi J, try using different internet browsers. Cycle through such as use IE, Firefox, Chrome, etc.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Tom Watts
-Tom
George Spanos
JH. Make sure you're logging into the GUI as the "admin" username. The "cisco" user has limited privileges. You can alternately upgrade the unit by using CURL and posting a .xml config file telling the unit where to go to upgrade.
Patrick Born
Hi JH,
As the others have said, first make sure you're logging in as admin. Secondly, if this is a new, never upgraded ATA, you'll have to use Internet Explorer for this first upgrade.
This Firmware Upgrade Process--Explained document and the ones referenced in it may help you:https://supportforums.cisco.com/docs/DOC-29477
Patrick---
   Use this reference document to locate SPA ATA resources
Hi all,
Thanks!
When I used IE I saw the firmware upgrade.
Thanks again!
Jan
