With enable secret set I can no longer access CCA 3.1(1)
m.castrigno
In config mode I enable secret password, now when I attempt to connect in cca it prompts me several times for the password which I provide, starts the software but shows my router as "Unreachable:Authorization Failed"
How can I fix this?
Thank you!
5 Replies 5
mzaccone
Is the user password the same as the enable secret?  Make sure they are the same as CCA will only ask for the password once so they must be the same.
After i login via telent how do I change the user password?
Thanks.
Hi Matthew,
if your user is e.g. "admin" then go to config mode and do the following the password should be the same as the enable secret.
(config)# user admin priv 15 password thesameassecretpassword.
HTH,
Alex
*Please rate helpful posts.
Thank you!
David Trad
Hi Matthew,
It should also be noted that if you change the user/pass via CLI and not with CCA, then you will most likely need to delete the community and recreate a new one to that UC, otherwise you may not be able to connect properly.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
