SPA9xx and SPA5xx LDAP Lookup for Inbound Calls
ryan-glenn
Does SPA9xx and SPA5xx support LDAP lookups for inbound calls? If the phones supports it, what settings need to be configured for this. If not, are there any plans in the future for this feature to be supported on these phones?
Alberto Montilla
Hi Ryan-Glenn;
The feature is currently not supported for inbound, it works for outbound only. It is not in the short term roadmap.
Alberto
Alberto Montilla
Hi Ryan-Glenn;
Alberto
CTRLITINC
Ryan,
The only way I know to do this would be to use Call Ctrl which will screen pop inside Windows for all incoming phone calls. There is support for LDAP and XML shared directory. This does require the additional software, but the only way I know how to accomplish your requirement.
Steve Wofford
www.uctrlit.com/CallCtrl
Call Manager for SPA IP Phones
Totaly_FuRy
This is a very good feature to add on the roadmap !
I have a growing fleet of 7800 cisco SPA500 and this feature will make my dream come true ^^
