UC320W and multi-tenant use
jeevan
I have a client that would like this product, but i'm not familiar with this line of product and its capabilities. I've deployed UC500s and know i can do it in that product, but not sure how customizable the UC320 is. we would like to find out if the below scenarios are possible.
The customer has two companies that it manages under it. for the sake of this explaination, let's call them Company ABC and Company XYZ.
the first part: the phone calls will come into reception. we would like it if line 1 (ABC) and line 2 (XYZ) were going to two different extensions that are setup on her buttons 2 and 3 (so that the calls are identifiable). is this possible with this system?
second part: if a user from ABC calls out, can we have them use '9' as their outside dialing prefix (whether to 1 or a group of more lines) and then have a user from XYZ call out using '8' as their prefix to call out a different group of lines. each company has their own set of lines to go out as with their proper caller id names. is this possible?
thank you in advance!
paolo bevilacqua
Wrong forum, use "small business - UC300". You can move the post with the panel on the right.
5 Replies 5
paolo bevilacqua
Oops! thanks Paolo! I hope I get the correct forum this time.
rsawyer6003
Seems like a reasonable request. The uc320w does allow you to route inbound calls from each fxo port to specific extensions. You can also map fxo ports and sip trunks for out bound dialing. Shouldn't be a problem.
P.S.
The receptionist would love the side car. Our receptionist loves single button transfers.
jeevan
Thanks Ryan! Good to know.
Jeevan,
The UC320 is not designed to work as a Multi-tenant system. You may be able to find some workarounds, but the customer has to be  very flexible if you would like to put it in an Multi-tenant system.
The only way this could possibly be done is to have the UC320 in key system mode and map a few lines to ABC and few other lines XYZ.  But note they cannot have individual AAs other individual services.
