VPN
Cisco CyberSecurity
Labels
Hello, I have dmvpn with hub and spoke topology. I route all traffic from spoke to HUB. So i have phsyical wan interface in vrf internet, point tunnel interface source vrf Internet, and have default route in that vrf internet. When i test speed it is...
mdzaf by Community Member
  • 124 Views
  • 0 replies
I am a Purdue student using Purdue's Cisco AnyConnect VPN. After I click "connect" and enter my password and make sure Duo Mobile approves, it connects, but only for 6 seconds before it says "optimization" and disconnects. This issue is sudden, it ha...
Aurora7 by Community Member
  • 218 Views
  • 1 replies
Hi Folks, I need Urgent help. I am trying to configure ikev2 tunnel between two CISCO Routers. However, the problem is that my router is behind a firewall and not able to properly route traffic to the other router. However, when i connect straight to...
Hi, after upgrading the ASA SHIMO VPN app stopped working. I noticed that openconnect stopps working as well and to fix this issue for openconnect I just added --useragent=AnyConnect and it started to work. I tried to add this to shimo in expert mode...
Hello, We previously had an IKEv1 VPN tunnel between a FTD 1140 and two ISR4431 routers, where we use the second routers IP address as a backup in the crypto map. We recently changed those tunnels from IKEv1 to IKEv2, but we have issues with the back...
Resolved! Gre and IPsec
Similar set up as a recent project. New customer, I suspect financial companies are trying to button up and make sure everything is encrypted these days. Here’s the setup, this time it’s all static routes. HQ router connects on a leased line to a rem...
ColForbin by Level 1
  • 255 Views
  • 2 replies
New to Cisco and anyconnect. I have created a anyconnect profile and after users is beginning to use the profile users are getting is error "Connection attemt has failed". I have only entered one server in the Serverlist.
trha by Level 1
  • 171 Views
  • 1 replies
I'm struggling with this issue, but Cisco is no help here with a weeks open ticket.  Moving from ASA to FMC/FTD setup for SSL Anyconnect VPN only, and we've got everything working EXCEPT for DTLS.  Having a real problem just troubleshooting this via ...
bnjones by Level 1
  • 8648 Views
  • 31 replies
I am trying to create a VPN connection to a Sonicwall running gen 7 os.  We already have two VPNs from the same Cisco to two other clients running gen 7 Sonicwalls.  I copied all of the settings and the Sonicwall shows connected with the green dot bu...
Scomage by Level 1
  • 983 Views
  • 12 replies
Hi All, I have done IPSEC setup as below(Link) where one end ASA has public IP and the remote end is dynamic and ASA is behind a NAT.  Configure ASA-to-ASA Dynamic-to-Static IKEv1/IPsec - Cisco Currently, the Hub CISCO ASA accepts IPSEC tunnel from a...
aprasad11 by Level 1
  • 330 Views
  • 4 replies
I hope that someone can clarify this to me. a site to site was configured properly without any problem . A NAT was required to change the source address, the destination is unique to the site(NO NAT) . the vpn was up but there was no traffic going ...
Top Solution Authors
