VPN
Cisco CyberSecurity
Labels
Hello,We have the following issue. Two-factor authentication (2FA) via Microsoft Authenticator is configured on a Cisco ASA. The tunnel group on the ASA is connected to Cisco ISE, which acts as a RADIUS proxy.In the condition, the Cisco ASA's IP addr...
Folks, I have an old school question. I have a use case that I think can be well met by using the Easy VPN solution using "Network Extension Mode" as opposed to "Client Mode". Is this capability still supported on new ASA firewalls or IOSXE routers? ...
Hi all!Under site-to-site VPN, in the Advanced->IKE Policies menu option, we can see IKEv2 policies list.If we change the priorities will it cause downtime on any established VPNs?By changing priorities I mean negating configuration and applying new ...
rikkm4n by Level 1
  • 277 Views
  • 3 replies
After starting anyconnect I find network connectivity stops working under WSL2 (Windows Substem for Linux)the fix seems to be: Get-NetAdapter | Where-Object {$_.InterfaceDescription -Match "Cisco AnyConnect"} | Set-NetIPInterface -InterfaceMetric 400...
Good day.I'm trying to encorporate some kind of MFA with Cisco Anyconnect's SBL (Start before login) VPN.The reason for this is we use SBL to log in users that do not have cached credentials on our devices that work remotely as they won't be able to ...
Hewitte1 by Level 1
  • 443 Views
  • 1 replies
  • 1 Helpful votes
