can I leave a message for a user without ringing their phone?
sweeneyjoe
can I leave a message for a user without ringing their phone?   in webex calling?
dtibbe
As simple as transferring a call directly to a VM: simply dial *55 followed by the user's extension.
See https://help.webex.com/en-us/article/5zw7v8/
12 Replies 12
Kathy N.
Checked our system as *55 does not let us transfer a call to the voice mail system unless 5 digits are dialed first and then it just places it into the system and the caller still has to input the vm extension they need to reach.  I don't find that very user friendly and if I tried to roll these instructions out the majority of our staff would be confused by it.
Response Signature
Kathy N.
@sweeneyjoe , note that this may be different in your environment.  For instance in our organization we have it programmed so callers just have to dial * before the user's 7 digit extension.  The *55 does not work in our environment.
Response Signature
Hi Kathy,  thanks for the reply.    *55  seems to work if we xfer a call to a mailbox,  but doesn't work if we just dial *55 and the number (no xfer involved)    can u tell me where I can enable this,   thanks.
@Kathy N., do you use Webex' Cloud Calling or UCM Cloud or so? The FACs for WxC are not changeable..
All of our services on our site @dtibbe.
Response Signature
Hi,  we use webex cloud calling
*55 feature code is used only for transferring an active call to voicemail. You can't just dial it with the extension. It will not work.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
In that case, I'd suggest to open a tac case because obviously either the help page is wrong or the function itself.
Unfortunately, I'm no more able to test it, so I rely on the documentation
dtibbe
Hi,  *55  seems to work if we xfer a call to a mailbox,  but doesn't work if we just dial *55 and the number (no xfer involved)    can u tell me where I can enable this,   thanks.
@dsweeny, I mentioned this above as it is configurable in your CUCM.  It would be part of the dial plan that you would need to check for a configuration that would transfer a call directly to voice mail.  In our system, the * key before the number does this for us.
Response Signature
thanks
