07-25-2022 01:46 PM
Hello, I have webex calling and I need 3 modes..Day mode, after hours mode, and end of day mode.
The receptionist will answer from 8-430. ext 18760
the tellers will answer from 430-6pm hunt group of phones
after 6pm,there will be a night message.
I created a schedule , but that only gives me open or closed, no thrid option.
Is there a way to do this? thanks
Solved! Go to Solution.
07-25-2022 11:09 PM
That's the way it is designed. There are just office hours and after hours. But you can youse the conditional call forward.
Or you forward all calls during day and after hours to a CQ and in night mode to a VM. The CQ itself may also have a schedule to either go to the queue or to the after hours agents. Basically the same as you did but with having the call forward in another place
07-25-2022 11:09 PM
07-25-2022 07:40 PM
I resolved by using 2 schedules in the AA fwd section.. But maybe someone has a better way..lmk thanks
