Quad Camera password
The default password for the Quad Camera serial port is not working. I used admin/cisco and shown in the this link but does not work. I also performed a factory reset a couple of time to make sure that was not the issue.
https://www.cisco.com/c/en/us/support/docs/collaboration-endpoints/webex-room-series/215671-console-access-for-webex-room-series-dev.pdf
7 Replies 7
JefersonViana
i just tried "admin" and password blank, but is not working. Our quadcam is not recognized by Codec. Was already performed reset factory and changed HDMI and network cable but not solved
The quadcam is not at codec, it has no web interface, the person on this thread previously was referring to the codec the quadcam was connected to I'm assuming, but you're mentioning the codec separatley, so I'm not clear on what you're trying to do.
Yes quadcam is conected on Codec by cable HDMI and ethernet. I'm connected directly on quadcam by serial cable. The issue is in our Quadcam only, the Codec is working fine. Was tryed reset factory on Quadcam but it was not solved
Are you sure you have the ethernet cable connected to the right port on the codec? What codec are you using? On the Room Kit Plus you should be using the right most of the three network ports.
The quadcam is not working with Codec, was tried reset factory on both devices but not solved. Codec is working fine, but quadcam no. Was checked and changed all cables and are connected correctly. I'm trying connect on Cam by console CLI to check erros, but admin password is not working
Wayne DeNardi
Those instructions are incorrect for a device running a recent software version.   The default username is still "admin" but then leave the password blank.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
