DevNet Collaboration
Check out the latest APIs, SDKs and resources for Cisco Collaboration technologies and engage with peers and experts.
Intro to Ansible
Good Documentation
The Great Selenelion
>> View previously featured conversations <<
Activity in DevNet Collaboration
XBusyLampField specifies minOccurs=1, which contradicts annotation, RBusyLampField behaviour and other AXL call choice options
Hi,Looks to be a bug in XBusyLampField in 11.5 AXL.The schema is: <xsd:complexType name="XBusyLampField">         <xsd:sequence minOccurs="0">             <xsd:element maxOccurs="1" minOccurs="1" name="blfDest" type="xsd:string">                 <xsd...
Get Device Serial Number
This document was generated from CDN thread Created by: Mayank Sharma on 12-01-2009 03:56:36 PM Hi again,Is there a way to access the device information like Serial Numbers? I could not find any table that stores that.I am using CUCM 6.1.Thanks,MaxSu...
cdnadmin by Community Member
  • 11410 Views
  • 4 replies
  • 11 Helpful votes
Can CURRI be used for Post-Answer Treatment?
Deploying a contact center solution with a customer requirement that on every outbound call made by their agents, they would like the called party to immediately hear a message as soon as they answer. For example, “This is ACME calling. This call may...
ramvelez by Cisco Employee
  • 184 Views
  • 0 replies
Welcome to the Spark Game of Life!
People have been asking us – how do you use the Cisco Spark APIs?  At Cisco Live! Berlin, Cisco DevNet attendees met the Spark Game of Life for the first time – one of our favorite early examples of the Spark platform APIs at work.The Game of Life is...
jodecast by Community Member
  • 1405 Views
  • 1 replies
  • 2 Helpful votes
Grammer error with choice element
This document was generated from CDN thread Created by: Grant Bagdasarian on 24-06-2013 07:24:12 AM Hello,Using Cisco 3925 - IOSVersion 15.2(3)T. No CVP. VoiceXML applications are registered on incoming dial-peers.I'm receiving an error for the follo...
  • 492 Views
  • 1 replies
How to Embed an Application iFrame in Cisco Finesse
Description:I want to open or embed my custom application i Frame inside Cisco Finesse. I am looking for guidance on how to configure it so that the application loads properly within the Finesse interface.Specifically, I would like to understand:How ...
Tom-shelby by Community Member
  • 1011 Views
  • 4 replies
Resolved! HubSpot Integration With Jabber
We are considering their SupportHub product and have the requirement to link incoming calls to their interface to retrieve caller details and history. I am told that their Contact API - Get endpoint will provide that functionality but we will need to...
API to get number of registered phones
I have don't quite a bit research and didn't seem to find a perfect answer. It's a simple task for RTMT to find the number of registered phones in a cluster.  Not so simple from application perspective.   Method 1: Use Risport70 API (https://develope...
luoht by Visitor
  • 4362 Views
  • 5 replies
Top Experts - Last 30 Days
