AP 3700's Not Joining 5760 Controller
bm_5789
I am trying to get 25 3700 ap's to join an existing 5760 wireless controller.  There are already 150+ ap's joined and have been for 2+yrs.  I have licenses and the country code is correct.  An ap will appear to join the controller and then disappear from the controller.  This is happening now for over 12 hrs.
I am attaching the log from the controller.  The same entries appear repeatedly.
16 Replies 16
I took a screenshot of a joined ap3700.  It is the attached.  The 8.2.105.x is the primary software version currently on the ap with the issue.  It should be 10.2.170.
TIA
I've never seen that version. Doesn't mean it is impossible, just rare.
I sadly don't know any further here, besides maybe manually imaging the AP, but that would take a long time. I suggest you open a TAC.
