140AC DNS error?
DaveCisco2023
I have a 140AC and when trying to update the firmware from within the AP UI, I select cisco.com, I get the following error when trying to check for an update:
DNS: IP Address Not Found
The problem is that I cannot find anywhere in the setup to define DNS settings??
Maurice_
DNS settings are in Advanced > Primary AP Tools > Troubleshooting Tools. There you can also test name resolution.
Maurice_
Thanks!!! Never thought to define something there.
