03-12-2013 06:50 AM
When trying to delete an interface from the Interface Groups, I am getting an error "Interface group is being used by AP Group." Is there a way I can go in to delete the interface?
03-15-2013 01:55 PM
Hi toupheng.her, thank you for using our forum, my name is Johnnatan I am part of the Small business Support community. In this case you need to disable all protocols or vlans where you are using the group that you want to delete, probably a vlan is using your group and that´s why you can´t delete it, then you will be able to delete it. You can also search ACL, VPN, NAT, etc... I hope you find this answer useful,
*Please mark the question as Answered or rate it so other users can benefit from it"
Greetings,
Johnnatan Rodriguez Miranda.
Cisco Network Support Engineer.
06-12-2013 01:01 PM
I have the same problem, only I have no AP groups using the Interface group.
06-12-2013 02:39 PM
Hi jlhainy, my name is Luis I am part of the Small business Support community. Did you try to delete the group following the instructions above? This message appear when you are trying to delete a group that is using in this moment, happen the same if you try to delete a folder when you are using it.
Greetings,
Luis Arias.
07-15-2013 09:48 AM
Hi Toupheng
May I know the device you are using so that it will easy to guide you
Thanks & Regards
Punith Kumar Neelam
SBCD Engineer
07-15-2013 09:50 AM
I have resolved the issue. Thank you,
