Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gear Support page index - Contains ...
Hi!I´ve just bought a SG100D-08P to provide PoE for two AP541N in our small business. Will this switch provide enough power over ethernet for these two? Or do I need a bigger switch?Thanks in advance!Ingar
Hi,first sorry for my english, its not the best.I have bought 3 Cisco WAP321 and a SG100D-08P PoE Switch, when i connect one of the accesspoints to the PoE-Port of the Switch, it doesn´t work, but when i connect an accesspoint via a power supply it w...
This is a complete newbie question, but I can't seem to find the answer in any of the technical pages. We would like to set up a guest access point for visitors to our business, but we would like to require them to self register the first time they u...
Hi,We have 2 updated WAP4410N and for both I have problem with SNMP. I have 2 monitoring tools in different location trying to get info out of it (PRTG and Cacti). It works for 15minutes, graphing the bandwidth of the interface and then it stopped. I...
We support 5 WAP4410n at 3 different sites. They all exhibits the same connectivity issues. The WiFi connection will freeze/drop all users at random intervals. A hard power cycle is require to bring them back online. When the connectivity issue h...
Hi all,I inherited this device and wanted to use it in my home network which has a Cisco router that provides DHCP leases to all network devices, as well as acting as an ADSL modem connected to my ISP.When I connectec the Cisco WRV210 to the router, ...
Hi,I have an old computer with dead wifi nc and I thought that bridging it with was121 should work, but can't find anywhere any comprehensive documentation on how to set it up. Any help,please?Thanks
As the title says, I'm having trouble working WAP321 cluster mode.The problem basically is that sometimes users to connect to the wireless network, the APs do not request authentication through captive portal and users connect directly to the Interne...
please help me to understand what is the meaning of Acess point Channel utilization? If i want to mange the capacity of my Office Wi-Fi network what are the factor i need to monitor.
Hi there everyone,Looking to have an issue of mine resolved. Currently I am running 4x WAP4410N access points configured with a single corporate ssid with WPA2 Enterprise authentication which is pointing to a network access protection server. What ...
Hi,I've configured both the RADIUS server and verifies EAP-TLS authentication via clients. This is however not 802.1x, I want to make the device work with 802.1x via the air to route clients properly. However as it is now, I am unsure on how to confi...
Hi there, I've a new Microsoft Surface Tablet since two weeks and I'm very happy with it. But unfortunately it has some trouble connecting to my WAP4410N.I've set up the WAP4410 as a B/G/N Mixed Mode AP, WPA2 Personal with AES. All clients (Android P...
HiI have a couple of networks that contain these access points in cluster mode. All seem to have intermittent DHCP issues that worsen with AP uptime (i.e after a few days to 2 weeks). Client devices will successfully associate with the AP, but do n...
Hi All..I'm having some problems setting up a guest wireless. First of all let me explain our set up1 x ASA Firewall3 x SF 300-24P 24-Port 10/100 PoE Managed Switch's6 x AP541N-E-K9We have set up the company wireless which works fine.However i am tr...
Hi I have setup a Cisco WAP321 as an Internet Cafe Captive Portal. When initially switched on clients connect and are redirected to the Log on page where they can add their name and tick to say they agree with the usage policy.Works great, unfotunate...
