WAP121 can't set up
Selwyn29
I have finally managed to install Cisco FindIT to locate the IP address of the WAP121 attached to my network via ethernet, and now when I try and connect to the IP address I just get time out messages and took too long to respond.
Can anyone help????
5 Replies 5
Iliya Gatsev
My name is Iliya Gatsev from Cisco Technical Support Team.
I suppose that your PC and the WAP121 AP are not in the same network.
Please check what is the IP address of your PC and what address is showing the FindIT tool.
Please rate this post or marked as answered to help other Cisco customers.
Iliya Gatsev
Cisco STAC Network Engineer
Together we are the human network .:|:.:|:. CISCO
Yes they are both on the same network both connected to the router by
Ethernet cable
IP address of Cisco device is 192.168.1.245 (this is what is showing on
Cisco findit)
IP address of computer is 192.168.0.25
you should change the IP address of your PC to 192.168.1.25 for example.
Iliya Gatsev
Won’t let me it says chosen IP address is out of range
It will be good to call our support line and open a support case.
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Iliya Gatsev
