3802I - 3800 DOT1X 802.1x - AP does not leverage credentials
Jacob-Harris
Community,
We've used 3602's for some time now, and have configured them to leverage a user name and pass to authenticate to the network switches via 802.1x vs force authenticating the network ports for the AP's.
We've recently started to deploy 3802's and are not able to get them to authenticate to the network.
The controller supports this configuration, and we can't find anything that says the 3802 won't support this as a change.
Does anyone have any idea if somethings changed? or something special to get this working again?
21 Replies 21
jgardner150
Level 4
Level 4
We just took a look at the 8.2 release notes and it states it is not a supported feature on the 3800 series along with other x800 series.
Features Not Supported on Cisco Aironet 1810 OEAP, 1810W, 1830, 1850, 2800, and 3800 Series APs
Table 12 Features Not Supported on Cisco Aironet 1810 OEAP, 1810W, 1830, 1850, 2800 and 3800 Series APs
Operational Modes
  • Spectrum Expert Connect
  • Workgroup Bridge (WGB) mode as a part of Cisco Mobility Express
  • Mesh mode
  • Flex plus Mesh
  • 802.1x supplicant for AP authentication on the wired port
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn82mr1.html
Seems like it will not be supportet in 8.2 and also not in 8.3.
Just got the info, that it will be back in a later release in about a mounth.
hi
we are in 2018, april, and it seems it is not available even in version 8.5 ?
https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn85mr2.html#not_supported_key_AP_features_85
cannot believe that it's been removed
any idea if this feature will be added ?
GREAT, if it is finally comming ..
It seems now supported in WLC 8.6 bus this version doesn’t work on a WLC2504.. arghhh... Cisco.. what the f@#%^k. Anyone tips how to make this work?? (wlc2504+2802i)?
Disable 802.1x on the port where the AP is connected to. There sadly isn't really another way.
Thanks, i already came to the same conclusion that using MAB or completely disabling dot1x on the port is the only option for now..
What you could do, try to raise a TAC for backporting this feature into the older 8.5 version. I wouldn't have much hope that it will get integrated, but you never know.
I've created a TAC case and contacted our Cisco sales representative so let's hope for the best. If anyone that whishes to use this feature creates a TAC case we maybe have a chance..
Did you get any response from TAC on this?
It appears that they are finally doing something about this in the 8.7 release. And rather than just having username/password you will actually be able to use cert based auth (EAP-TLS / EAP-PEAP). Fingers crossed it actually works there, we're still on an 8.5 release and it doesn't look like there are any stable 8.7 releases at this point.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-7/b_802_1x_eap_supplicant_on_cos_ap.html
Last comment that i got from Cisco sales is that they suggested that i should buy a new WLC, for example the 3504.
Great. So don't fix it, just buy new.... Not a great answer !!
