04-07-2017 02:21 AM - edited 07-05-2021 06:49 AM
We are pleased to announce Beta Refresh Release for 8.3MR2.
Please Register at below link to participate in the Beta Program. Once Registered a separate Email will be received with Software Download Link.
Resolved Caveats
Identifier | Headline |
CSCvb05067 | Local EAP fails after wrong username login |
CSCve01552 | Unknown Username when switching from open to dot1x SSID |
CSCve13183 | AP2800/3800/1800 WCPD Crash with clients connected and can't recover after crash |
CSCuz47559 | error saving config file happens on multiple 2702 |
CSCve34143 | Wlan-vlan mapping not working sometime when ap removed and added back in flex grp |
CSCvd20251 | DP stopped working on 5508 running 8.0.140.0 |
CSCvb93365 | WLC msglog showing a lot of traceback |
CSCvd72432 | LocalEAP LDAP Request With Incorrect Password Lockout Users |
CSCve05840 | Addition of DP show commands as part of show run-config |
CSCvb74948 | AVC - CISCO-JABBER-IM application is getting misclassified as SSL |
CSCvd36259 | ME Controller intermittently Flaps with external AP. |
CSCvd96491 | SR: Rest/API for WLC exposing Assurance login password |
CSCux11777 | 1532 non-root bridge high retransmission and latency rate |
CSCvb62874 | Radio interface Input queue gets filled on Autonomous APs. |
CSCvc49713 | AP generates flood of Received and decoded a DMS client request payload SUCCESSFULLY |
CSCvc81929 | Mobility Express crashes when DHCP screen is accessed |
CSCvd58113 | wlc allowing telnet and ssh over ipv6 on global telnet and ssh disabled |
CSCvd66657 | AP 3802: SensorD stuck in offchannel causing radio stops working |
CSCvd90117 | AP3800 - Radio crashing frequently due to beacon stuck |
CSCvd92166 | Couldn't pass host testie build in the branch 8.3 mr throttle in richardson ads, but can pass in sjc |
CSCvd99909 | 8.3 MR2: AP 3800 - 5G Radio crashes - when SI enabled |
CSCve07524 | In GUI 11ac config behavior mismatch with CLi for different AP mode |
CSCve06701 | Client stuck in DHCP_REQD on flex AP after changing native vlan |
CSCvd43728 | Ap1850 DTLS Teardown after channel change |
CSCve18484 | Clear data icon is not working if other languages like korean,japanese is selected in browser |
CSCve13073 | MC9090 doesn't join with 11g disabled |
CSCve01109 | SXP connection on WLC stays off. |
CSCve21379 | During Auto Provisioning Feature, Radius Server Templates are getting applied but staying Disabled. |
CSCvc44293 | 8.4 - ME UI - Changing Transmit power on UI does not work |
CSCvd67178 | Anchor not deleting webauth req client beyond webauth timeout |
CSCve09531 | v6udp_csum_buf overshooting the buffer resulting in WLC crash |
CSCvc81082 | Polaris XOR: The radio is updated as UP whenever AP's XOR band is configured eventhough POE is low |
CSCve17730 | Kernel panic seen due to wlTxDone in 8.2.151.7 |
CSCux97132 | AP starts CAC timer after rolling back to lower bandwidth |
CSCvd53205 | DCA lists in RF profiles are broken after backup/restore the WLC's config |
CSCvd87065 | WLC crash due to task nmspTxServerTask |
CSCve17355 | Upgrade to WLC - 8.3 software enables 11k & 11v by default on all WLANs |
CSCvc41484 | Corsica: high failure rate in off-channel operation, QCA 2721453 |
CSCvc86951 | AP1850 beacon miss/corruption during downstream traffic test, QCA 02793762 |
CSCvc98310 | AP 1830: 2.4-GHz radio stopped working @0x009915D7, QCA 02797962 |
CSCvd18732 | AP 1810 radio FW Assert @0x0099B2DA in overnight multi-client test, QCA 02818890 |
CSCvd28594 | Client association fail after altering data rates in AP 1830. |
CSCvd28645 | AP sending RTS at 6 data rate when data rate 6 is disabled, QCA 02829301 |
CSCvd77037 | AP1832 sending instant ACK after CTS that block data from client, QCA 02862955 |
CSCve00464 | AP1852 detects high noise level on 5-GHz radio for every channel except the serving one |
CSCve10751 | Clients cannot assocate with AP after changing from DFS to non-DFS channels during CAC, QCA 02910240 |
CSCvb57350 | SNMP trap for "AP Interface Up/down Traps" not getting generated. |
CSCvd69782 | Roaming L3 test was failed with 50% in Talwar and Pata WLC |
CSCvd80962 | 8.3MR2: LWAPP-3-AP_LOCK_ERR traceback observed on WLC for AP2800/3800 AP |
CSCvd81926 | CCX Proxy arp flag not set in IOS APs |
CSCve08894 | Unable to debug VRRP issues unless have devshell access |
CSCvb70551 | COS AP's rebooted due to Kernel Panic-Not Syncing: Out of Memory |
CSCvc81429 | 8.2MR5: AP3800 throughput drop in client scale test with random client MAC addresses |
CSCvd61747 | AP3800: Radio crash due to off channel stuck due to defer_chchange_flag always set to TRUE |
CSCvd91894 | 3800/2800 kernel panic crash PC is at mv_dev_kfree_skb+0xc/0xa4 [ap8x] |
CSCvd96867 | Sanity: radio1FW core found in ap1560 with 8.4.2.52 |
CSCve14081 | AireOS: Same channel has been assigned to both the 5Ghz Radios after capwap restart |
CSCuw45964 | Mobility Express: While Editing a WLAN in HTTP session ,user is getting logged out |
CSCvd37808 | 8510 WLC stopped working - iappSocketTask |
CSCvb04932 | APs not discovered because of wrong bsnAPIfType returned for 1810W |
CSCvd06463 | AMSDU packets tx cause 5sec gap of packet tx to 8821 from IOS AP |
CSCvd44446 | Retried EAP Response Dropped as a duplicate while First EAP Response was not even received on the AP |
CSCve30199 | CCKM PMK (Version 2) message flooding 8.3MR2 |
CSCve23103 | AP3800: False RADAR detection without RADAR source |
CSCve23874 | BARBADOS-Client got associate immediately even if CAC timer start on AP log ,when DFS channel is set |
Resolved Caveats
CSCvc67005 | 2802 AP drops client ARP packets after web authentication |
CSCvc08052 | DFS false detection on AP2700 |
CSCva90265 | iPAD PRO with IOS10 is getting deauthenticated at times due to M3 timer |
CSCvc86170 | ClickAP FlexConnect Local Auth doesn't work on WLAN with CCKM security |
CSCvd85995 | AP3800:AP deauth client after roaming and doesn't send deauth when client sends qos null |
CSCvd18773 | 8.2 clients unable to authenticate 'Sending assoc-resp with status 12 station' |
CSCvd90669 | Need support for AAA override w/ MAC filtering on RLAN |
CSCvd79597 | Smart License 5520/8540 : Unable to reset HTTP-Proxy on Call home configuration from GUI |
CSCvd70755 | AIR-AP3802I crash due to kernel panic |
CSCvc49492 | AP1852 detects high noise level on 5-GHz radio |
CSCvd56581 | Client not getting IP address when moving between SSID |
CSCvd14806 | APs randomly not showing any neighbors on both radios |
CSCvd97103 | IPv4 CPU ACL - IP-Address with netmask other than 255.255.255.255 doesn't work |
CSCvd98548 | Kernel panic inside ForwardFrame function! |
CSCva17630 | WLC sends warm-start trap instead of cold-start during autoprovisioning |
CSCvd54154 | All AP1850 connected to master AP crash in a loop due to watchdog reset |
CSCvd86274 | 1800/2800/3800 Series AP does not send the Platform value via CDP when it is brand new |
CSCvc74876 | 8.2.145.21: Barbados CAPWAP disconnect then stuck in discovery loop |
CSCvd91770 | Trust-DSCP-Upstream broken on 8.2.151.0 |
CSCvd88630 | AP 3800: Ap crash due to 'wcpd' in 8.4 |
CSCve01859 | With FIPS enabled on 5520WLC, 3802AP shows no 5Ghz neighbors |
CSCvc82845 | WLC returns nothing for SNMP get WEB ACL - cldcClientAaaOverrideAclName |
CSCvd36736 | AP in local sw/local auth disconnect EAP-SIM client idle for more than 0.5 second |
Resolved Caveats
CSCvd40646 | AP2802 - Kernel Panic - Dot11Classifier: Mgmt frame not supported 0 |
CSCvd69992 | AP: 2800/3800 unable send proper sequence# and burst rate upstream |
CSCva44397 | WLC gateway not reachable after disabling LAG |
CSCvc15976 | Trustsec: AP: Not able to enable/disable AP inline tagging and SGACL Enforcement via SNMP |
CSCvb54392 | 3800: MacBook Pro Clients with OS X 10.11 getting stuck in DHCP_REQ |
CSCvd46216 | AP1832 sometimes does not send authentication response |
CSCvd46314 | Standalone COS AP should reject new client if MAC auth is configured |
CSCvd72664 | 1850 AP sometimes tags 802.1q vlan for native WLAN, causing ARP packet drop |
CSCvd74063 | AP1832 Crash due to watchdog reset(wcpd no heartbeat) |
CSCva26821 | Auto Anchor Deployment: Scheduling deletion of Mobile Station fails |
CSCvb77390 | WLC stopped working accessing MAC Address Database |
CSCvd32632 | Standby Controller stopped working @rmgrReboot |
CSCvd42348 | Standby WLC stopped working on performing SNMP Set on bsnDot11QosProfileEntry |
CSCvc85164 | 11k: WNM neighbor report is empty in when WLAN ID is greater than 1 |
CSCvd61977 | 2800/3800 -radio coredump generation may stuck ca_status leading to IPC call function failures |
CSCva33212 | Re introduce auto provisioning feature on WLC 2504 running 8.0 |
CSCva46506 | Flexgroup RADIUS configurations are not pushed to AP |
CSCva84030 | Increase CLI WLC username and password to 128 char for TACACS support. |
CSCva88600 | Evaluation of WLC for TCP August 2016 |
CSCvb71600 | WLC stopped woking after applyng CPU ACL |
CSCvc40852 | 82MR4. Active controller in HA pair shows different socket errors |
CSCvd50044 | System stopped working multiple times on ping rx task |
CSCva88319 | 5508-HA-WLC stopped working with Task Name: TransferTask |
CSCvb64042 | WLC HA transfer download failure with legitimate network latency |
CSCvb93189 | AP drops Retransmitted M3 from WLC |
CSCvd15742 | AP crash with %ENTROPY-0-ENTROPY_ERROR: Unable to collect sufficient entropy |
CSCvd83741 | AP: 1850 unable send proper sequence# and burst rate upstream from AP to MSE |
CSCvd30952 | RM3010L-B-K9 Hyperlocation Module stopped working |
CSCvd81303 | 2800/3800: Limit 'best' DCA to 80 MHz also for RF profiles |
CSCva14667 | GET on Ap groups Table after set - response missing |
CSCvc94648 | Evaluation of wlc for OpenSSL Jan 2017 |
Resolved Caveats
CSCvd24540 | SNMP System crash when tried to create tunnel with clGatewayTunnelEntry MiB |
CSCvd19354 | WLC crash while editing config rf-profile hsr-mode disable | enable config rf-profile 11b |
CSCuz47786 | FlexConnect AP sending IGMP report to WLC for local switching WLAN |
CSCvb86157 | clients can't connect anymore to vWLC- Instrumented code added |
CSCvc67465 | Flex AP loses vlan mapping if vlan tagging is enabled. |
CSCvd37960 | 83MR2-clients getting re-anchored if critical application is present on client |
CSCvb64560 | CISCO-LWAPP-AAA-MIB: DEFVAL format incorrect for some objects |
CSCvb67724 | 5508 is going out of memory |
CSCvb69962 | Client traps not showing session ID's |
CSCvb98859 | AP in local sw/local auth disconnect EAP-SIM client idle for more than 0.5 second |
CSCvc52210 | After reboot of the Master AP, CMX connector service has to be disabled/enable for Test link to work |
CSCvd33140 | ME 8.4 - Constant increase in WLC Memory reaching 90% and above |
CSCvd35988 | 8.5 5520WLC-HA causing DENY rule on WLC and Telnet&Gui access down |
CSCvb20553 | Coa for session timeout not working using free radius server |
CSCvb53368 | validate rogue clients against AAA not work |
CSCvc11630 | Radio reset in switching to connected mode from standalone |
CSCvc24485 | #APF-3-UNKNOWN_RADIO_TYPE: [SS] apf_utils.c:571 Unknown Radio Type 0 from Standby flooding syslog |
CSCvc65675 | WLC: Constantly increasing memory consumption by SNMPTask |
CSCva72390 | 8.4.1.27 - Corsica in Bridge intermittently stalls show commands ... |
CSCvc03468 | 2800/3800: Packets not beamforming with beamforming enabled. |
CSCvc49263 | RLAN-VLAN mapping misconfigured after moving to secondary |
CSCvc55328 | AP crash due to kernel panic at WlLoadRateGrp |
CSCvc86979 | 2800 AP silent reboot with NUL print every 10 mins continuously |
CSCvc93398 | AP2800/AP3800 MU-MIMO forms MU groups with 2SS clients |
CSCvc95222 | 1810w LAN port dropping IPTV packets when wired device is 100M(QCA 02835075) |
CSCvd20271 | Ap 3800 crash 8.3.104.131 in Monitor mode with wips submode |
CSCvd27285 | ME_1852E : CCO image download re-initiated on the APs on which the Dwnld was alrady completed |
CSCvd29564 | Layer 2 Packet Drop Of CDP Packets for COS APs |
CSCvd35231 | AP1810W: Reload Reason: 0: Unknown aka Silent Reboot |
CSCva99545 | Invalid information displayed in show cert webauth/webadmin |
CSCvb45130 | Part of ATF config is not pushed to uploaded config |
CSCvb62478 | Wlan is allowed to be enabled when FT enabled without FT-psk/FT-802.1x |
CSCvc61652 | m25/1.0 is shown in client info |
CSCvc63169 | Flex AP specific WLAN-VLAN Mapping lost on rebooting the AP |
CSCva99052 | Configuring 1810W to OEAP does not enable DHCP on Local port LAN3 |
CSCvb29996 | 1810W Hardware Watchdog reset crash PC=0xc03b3ffc, LR=0xc008af24, QCA 02698633 |
CSCvb54306 | 1815: LED blikning green - light green even at full power and clients connected |
CSCvc07184 | Media streaming behavior different between 1560/3800 and 3700 |
CSCvd20843 | Beacon stuck due to off-channel stuck |
CSCvd21051 | AP3800: Kernel crash at wlTxDone+0x190/0x688 [ap8x] |
CSCvd51674 | AP1810W: Silent reboot : revert highest power table value |
CSCva81406 | WLC - Unmap deauth reason codes 13-22 from reason code 15 exclusively |
CSCva92917 | Observed Traceback logs in show msglog and logging |
CSCvc83583 | 5520 controller crashed with taskname apfProbeThread |
CSCvc87433 | Webauth with proxy doesn't work after 8.2 |
CSCvc88997 | FRA probe suppression config not saved after WLC reboot |
CSCvd01586 | WLC crash - Task Name: RRM-DCLNT-2_4 | rrmClientCoverageHoleAlgorithm |
CSCvd05332 | After changing AP mode to FlexConnect, AP does not assign IP to RLAN clients |
CSCvd06848 | crash SNMPTask Reason:System Crash |
CSCvd07423 | AP firmware corrupt after power cycle bad mzip file, unknown zip method reboot loop |
CSCvd15404 | Rule creation with CLRuleConfigEntry crashes the controller |
CSCvc07521 | AP3800 sends A-MSDU larger than client can handle |
CSCvd25231 | Collect Stack info for silent reboot of 2800/3800 |
CSCvd33219 | AP 3800: FW hang detected - chatter: wl1: fwHangDetect(357): FTR! |
CSCuz16883 | Address registration issues for mobility scenarios |
CSCva68921 | WISM2 reaperWatcher got stuck on DP0 while retriving crash and crashed |
CSCva77707 | AIR-CT5508 SSO ARP request out redundancy management sent with wrong MAC |
CSCva79367 | Cannot add or delete Syslog Servers To WLC |
CSCvb44979 | WLC Local EAP with 7925 Handshake Failure |
CSCvc04089 | 2700 series AP radio resets reason code 71 RADIO_RC_NO_REPORT |
CSCvc12594 | Controller fails to send SNMP when using untagged interfaces on different ports |
CSCvc78510 | 2702 aux port goes to disabled after the ap is rebooted |
CSCvd53765 | After restarting WLC NMSP goes down on CMX |
CSCuz70879 | MAP reloads on hitting 40 mins timer even when it is downloading image |
CSCva06617 | 8.3Beta :Globally configured ATF mode not applied to newly joined AP2700 |
CSCva20342 | WGB uses incorrect MAC while trying to setup BA |
CSCva31890 | MIB table bsnMobileStationPerRadioPerVapTable has no data |
CSCva39537 | 802.11h configuration not saved after restoring config backup |
CSCva40580 | 8.3:BulkSync on active wlc never completes and is stuck in 'in-progress' |
CSCva83802 | HA: SSH on redundancy management interface rejected |
CSCva91483 | AP2700 failing co-channel fairness with Samsung S5 |
CSCvb11778 | 8.1.131.18 WLC crash on sisfSwitcherTask |
CSCvb48354 | RRM Not updating as per configured on WLC |
CSCvb57779 | APs unable to join WLC in different subnet through gateways with proxy-arp disabled. |
CSCvb61023 | DHCP Option 82(remote-id) not present is some AP |
CSCvb81940 | Vlan tagging for external module removed from Ap after upgrade to 8.3.102.0 |
CSCvc39231 | SNMP GETBULK on cLIpsecProfileTable returns with No response from controller |
CSCvc68156 | Full support for "distance" on AP1572 |
CSCvc79811 | When adding/removing country codes 2.4GHz channels change |
CSCvc83490 | Redundancy Mobility MAC does not stay, Primary WLC's MAC is always set instead |
CSCvd09240 | Local-auth EAP-TLS win10 not working |
CSCvc62277 | 5520 crashes on running rrm commands on task emWeb |
CSCvc85328 | AP1832/1852: Power injector/Normal mode inspite of power supply by AIR-PWR-C |
CSCvd15394 | 3800 AP will reject login for login credentials with childer ~ in password |
CSCuz77859 | Flexconnect: AP specific DHCP-NAT-PAT config does not apply in the WLC |
CSCvb12026 | Client Load Balance export to Anchors Fails with New mobility enabled |
CSCvb51570 | WISM 2 crashed on upgrade to 8.3.102.0 with Task Name: spamApTask6 |
CSCvb89781 | 2700-B AP unable to join WLC: Unable to create temp dir "flash:/update" |
CSCvb97383 | WLC deauthenticating roaming client with idle timeout |
CSCvc33793 | WLC tears down connected AP due to unequal loadbalance between SPAM queues high load |
CSCvc83175 | VWLC does not learn client IP / Client stuck in DHCP_REQD |
CSCvd00067 | wired WGB client is removed from parent AP's association table |
CSCvd18025 | anchor1 wlc does not free client sessions after client roaming to anchor2 wlc-client entries stale |
CSCvd21155 | WLC Crash when multicasting traffic and accessing WLC GUI |
CSCvd21969 | AAA AVC Override - AVC profile retained after roaming |
CSCvd41350 | 83mr2-8500 crash osapiReaper fatal condition at broffu_fp_dapi_cmd.c:4574 |
CSCvd56671 | WLC Crash : Task 'apfMsConnTask_0' in 8.3 MR2 |
CSCvc94524 | 2800/3800 iphone & android phones are not getting ipv6 addresses |
CSCvd00289 | 2800/3800 capwapd init unsuccessful creating 2 capwapd causing WCPD watchdogd reset |
CSCuz45986 | CWA not working on 8500 as Guest anchor with Accounting enabled |
CSCva66176 | AP drop of from Network due to large set of Mobility groups in down/down |
CSCva95121 | Stale IP route left on Flex AP config if booting up in standalone mode |
CSCvb13666 | WiSM2 crash with Task Name 'IPv6_Msg_Task' |
CSCvb15871 | aIOS not forward broadcast multicast frames with dynamic vlan |
CSCvb16806 | 5500 MC showing stale connections from MA clients |
CSCvb33076 | WLC: GUI does not allow to change sniffer channel |
CSCvb96009 | WLC Crashed on emweb task on 8.3.102 |
CSCvb99468 | AirOS WLC crashed in emWeb when serving an EmWebForm exclusion-list |
CSCvc66352 | 5500 controller crashed with taskname emweb |
CSCvc74515 | 8.2.121.11/8.2.124.15 : WLC Data plane crash due to fragmentation |
CSCvc78546 | WLC sets Zero 11e QoS for downstream voice traffic when CAC is disabled |
CSCvd39346 | 2800/3800 WCPD slow memory leak |
CSCvd49909 | Kernel panic @ ClientCapabilitiesTracker virtual address invalid |
CSCvb91652 | PMIPv6 Sluggish cli/gui response as well as sporadic lack of snmp response |
CSCvc23724 | WLC crash with EoGRE Heartbeat and skip count configured with value 0 which makes tunnel dead |
CSCvc65568 | 8821 fails 11r FT roam with "Invalid FTIE MIC" |
CSCvc82053 | The nmsp info/probe notification queue is saturating |
CSCvc82376 | EAP-TLS certs and PMK cache are missing on Flex AP after reload |
CSCvd12057 | Flex AVC : Downstream QoS marking not working - 8.3 |
CSCvd56064 | Flex local switching, local auth not supported when PMF is enabled in 8.3.114.22 |
CSCvd61701 | SSH to Standby RMI or Service port Fails |
CSCuq05475 | Controller GUI shows AP's NAT IP instead of private |
CSCvb12565 | WLC stops working when running 'show run-config' command with no APs |
CSCvd48333 | Controller stopped working : emWeb |
CSCvd63242 | Click AP not associating with 11r client in flex connect mode |
CSCux83260 | BGL-Alpha: "lbs-ssc" &" sha256-lbs-ssc" missing in WLC web UI |
CSCva85361 | WLC losing IPv6 Connectivity |
CSCvc41438 | WGB running 15.3(3)JD WGB takes ~500ms longer to scan DFS channels vs JBB |
CSCvb35865 | AP2800 crash for flexconnect-Sensor-Flexconnect |
CSCvc83465 | 8.3MR1: 3800 AP sometime stops sniffing on DFS channel |
CSCva64515 | %SPECTRUM-3-CA_LOGMSG: SPECTRUM LOG: invalid radio type |
CSCvc40267 | WLC sends wrong VLAN for AAA overriden client re-associating to AP belonging to FlexConnect Group |
CSCvc74507 | Fix incorrect commit of CSCuu59589 in 8.0-mr |
CSCvd27065 | EAP-FAST EAP-Chaining on Wired 1810W port does not work |
CSCvd58664 | AP dropping EAP packets on Radio which is seen on Wired uplink |
CSCvd56422 | Error cause 403 generated for 'RFC-3576 Disconnect-Request' |
CSCuz03702 | New mobility:Wired client behind WGB fails to pass traffic after roaming |
CSCva66489 | 11r sess timeout after reassoc causing Deauth 17 mismatch FTIE |
CSCvb94413 | 2800/3800: Fix DAA |
CSCvb97656 | Unexpected reload: Task Name: mmListen on 8.3.102.0 |
CSCvc28168 | WLC set ZERO 802.11e QoS UP for part of the downstream voice packets and APs trust it |
CSCvd06993 | Upgrade to 8.3 requires to reconfigure DNS server IP |
CSCva49263 | 802.11r re-auth failure after roaming |
CSCvb05494 | Wrong format of SNMP trap - mobility flap alarm |
CSCvc09824 | AP2800 band select stats counter show zero |
CSCvc18670 | WLC: Client stops passing traffic on DHCP Reqd. WLAN after sending a Reassoc request but no DHCP pkt |
CSCvc50436 | WGB wired client randomly stuck in the DHCP_REQD state after layer 2 roaming between the controllers |
CSCvc52093 | WLC send deauth 17 to phone in 4-way handshake |
CSCvc65641 | WLC reports tracebacks reported very frequently but no crashes |
CSCvd07215 | AP1810/2800 doesn't learn DHCP lease time from DHCP server and defaults to 24hr. |
CSCvc12566 | New transfer upload command for uploading bundled wlc log files |
Solved! Go to Solution.
07-23-2017 02:25 PM
We have been troubleshooting the exact same issue for almost two weeks. The audio quality and roaming where fine, however the 8821 phones randomly de-registered with CUCM (reason code 12 and 14) and also opening the global address book was sometimes troublesome.
The packet captures shown that sometimes TCP packets from CUCM towards the client where not being forwarded by the wireless network. Due to that the CUCM send a TCP reset or FIN explaining the reason codes. At this moment it is unsure if the root cause is on the controller or access-point side because we have also seen this issue with local switching. I'm also wondering if it only effects CUCM packets and if so why (size, payload, QoS marking?).
We have tested with AireOS 8.3.121.0 and 8.3.121.5 and both are having these problems. Due to that we are now run 8.3.112.0 with the "5 sec audio gap workaround" implemented and the situation seems stable.
07-23-2017 07:03 PM
Do you have Fastlane enabled?
We're (now) seriously thinking of rolling back to 8.3.112.0 or 8.3.112.7 Escalation Image.
07-24-2017 07:09 PM
Current plan is to back-out CSCvc78546 via CSCvf31894 which will be provided in 8.3 MR2 Escalation Image.
07-24-2017 11:23 PM
Thanks for your detailed response! :)
07-25-2017 04:01 AM
Thanks for the update, what about CSCvf29221 which we have ran into?
07-25-2017 04:59 AM
What's the timeline for the next escalation image of 8.3.121.X?
07-28-2017 07:28 PM
07-31-2017 04:55 AM
We are also testing 8.5.103.0.
08-01-2017 05:13 AM
How is your testing going?
We just received the release notes for escalation image 8.3.121.8 which are printed below.
8.3.121.8 is a build from the 8.3.121.0 CCO image and it is an engineering special that resolves the following additional caveat(s). This release can be used with 8821/7925/Spectra link with TCLAS/CAC enabled. In addition AVC/Fastlane can be
enabled.
CSCvf28445 WLC2500 been able to enable multicast to unicast
CSCvf09458 Cisco 2800/3800 series XOR radios are not moving to 5GHz or Monitor mode
CSCvd27398 WLC management access stops working while WLAN services are still up
CSCve06890 Randomly, Wave 1 APs can't send NDP Tx on all channels and can't be found as neighbors on nearby APs
CSCve20123 Corrupt voice packets are observed when a client with an active call does an inter-AP roam
CSCve49741 Cisco WLC fails to send SFTP and FTP when using untagged interfaces on different ports
CSCvf31894 Backout changes - CSCvc78546 that leads to CSCve20123
CSCve76202 WLC IPv4 CPU acl is applied as IPv6 CPU acl during backup recovery or SSO failover
I'm a little surprised to see support for multicast to unicast on the 2504 WLC being introduced in this release (if it is what I believe it is), but why not :-). We embrace the current "stable" situation with our end-customer and will not test this software ourselves.
08-01-2017 03:15 PM
Testing good, Freerk. The two bugs for the WiFi phones, CSCve20123 & CSCvf29221, seemed to be fine or not present with 8.5.103.0.
I will be upgrading a pair of 8540 in 11 hours from now. We'll see what happens.
08-03-2017 11:57 PM
Still running with the new version? :-)
08-04-2017 05:11 AM
Yes, a pair of 8540 on 8.5.103.0. No wireless voice issues observed.
08-06-2017 07:59 PM
I have had -lots- of serious issues with 8.5.103.0 and that was in just a lab environment with no voice. The worst were serious problems with my SGS8 phone and other Android devices disconnecting, and other issues relating to AP side disconnects with client side staying up (but with no connectivity).
8.4.100.0 has been my goto fallback release though which has been very good so far, but unfortunately it appears that 8.4 is probably only going to have a short lifespan. The focus seems to be on 8.3 and 8.5 stability instead.
08-06-2017 10:33 PM
Release 8.3.122.0 is a repost of Release 8.3.121.0 with the inclusion of three caveats in the Resolved caveats list.
There are no other updates in this release, all resolved and open caveats in addition to three resolved bugs apply to this release.
Caveat ID Number |
Description |
WLC management access stops working while WLAN services are still up |
WLAN in FlexConnect local switching drops NAC+802.1X and WPA2-PSK-WebAuth traffic on MAC filter fail |
Backout changes - CSCvc78546 that leads to CSCve20123 |
05-02-2017 05:07 AM
I installed latest 8.3/beta (coming from 8.2) in my prod environment and found an error displaying AP capabilities with 1262 (we still have a lot of them):
