01-08-2023 07:38 AM
I am studing Cisco's technology, and I want to make a LAB environment in my home, so I used 3 older 1700 series autonomous AP, and I tried to change the authentication method to username and password by using local RADIUS built-in. But no matter how I configured it, I could not get the user to connect to what I had created with the username and password I created. I configure serve management and the local RADIUS server under the security tab. In the mobile phone I see the WPA2 enterprise, but I enter the username and password I created in the local RADIUS server don't work.
I also configure a freeRADIUS in pfSense and try to use that, still has no effect.
But the WDS I configure by using RADIUS authentication work.
Any help would be appreciated, because I do not know what I may have missed, or if the security verification method is wrong.
01-08-2023 08:15 AM - edited 01-08-2023 08:17 AM
check basic authentication steps as below :
https://www.cisco.com/c/en/us/support/docs/wireless/aironet-1100-series/44844-leapserver.html
if you having issue run debug on AP and post the config logs here to understand the issue.
check some video examples:
https://www.youtube.com/watch?v=bWTt5EqmpQQ
01-08-2023 12:19 PM - edited 01-08-2023 12:31 PM
Thanks for the video, but I tried the video method it didn't work for my local RADIUS either.
Local RADIUS server statistics have no failures or successes attempt see: https://ibb.co/fGPQJcj
Here is my config:
Note: My VLAN 10 can talk to all VLAN, VLAN 20 is the web interface and Local RADIUS server, SSID "MAN" on the VLAN 10, is the SSID I am trying to use 802.1x authentication.
BOOTLDR: C1700 Boot Loader (AP3G2-BOOT-M) LoaderVersion 15.3() [ TRUE]
Product/Model Number : AIR-CAP1702I-A-K9
! Last configuration change at 14:27:49 UTC Sun Mar 7 1993
version 15.3
no service pad
service password-encryption
hostname HOUSE-Network3
logging rate-limit console 9
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxx
aaa new-model
aaa group server radius rad_eap
server name AP3-client
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius rad_eap4
aaa group server radius rad_acct4
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login eap_methods4 group rad_eap4
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa accounting network acct_methods4 start-stop group rad_acct4
aaa session-id common
no ip source-route
no ip cef
ip domain name HOUSE.local
dot11 pause-time 100
dot11 syslog
dot11 vlan-name Guest_Network vlan 40
dot11 vlan-name HOUSE_Network vlan 20
dot11 vlan-name IoT_Network vlan 30
dot11 vlan-name Management vlan 10
dot11 ssid HOUSE-Net
vlan 20
authentication open
authentication key-management wpa version 2
mbssid guest-mode
wpa-psk ascii 7 xxxxxxxxxxxxxxxxxx
dot11 ssid HOUSE_Guest
vlan 40
authentication open
guest-mode
mbssid guest-mode
wpa-psk ascii 7 xxxxxxxxxxxxxxxxxxxxx
dot11 ssid IOT
vlan 30
authentication open
mbssid guest-mode
wpa-psk ascii 7 0xxxxxxxxxxxxxxxxx
dot11 ssid MAN
vlan 10
authentication open eap eap_methods4
authentication network-eap eap_methods4
accounting acct_methods4
mbssid guest-mode
no ipv6 cef
username GABE privilege 15 secret 5 xxxxxxxxxxxxxxxxxxxxxxxx
bridge irb
interface Dot11Radio0
no ip address
encryption mode ciphers aes-ccm
encryption vlan 20 mode ciphers aes-ccm
encryption vlan 30 mode ciphers aes-ccm
encryption vlan 40 mode ciphers aes-ccm
encryption vlan 10 key 1 size 40bit 7 2B4859701297 transmit-key
encryption vlan 10 mode wep mandatory
ssid HOUSE-Net
antenna gain 0
stbc
mbssid
station-role root
interface Dot11Radio0.10
encapsulation dot1Q 10
no cdp enable
bridge-group 10
bridge-group 10 subscriber-loop-control
bridge-group 10 spanning-disabled
bridge-group 10 block-unknown-source
no bridge-group 10 source-learning
no bridge-group 10 unicast-flooding
interface Dot11Radio0.20
encapsulation dot1Q 20 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.30
encapsulation dot1Q 30
no cdp enable
bridge-group 30
bridge-group 30 subscriber-loop-control
bridge-group 30 spanning-disabled
bridge-group 30 block-unknown-source
no bridge-group 30 source-learning
no bridge-group 30 unicast-flooding
interface Dot11Radio0.40
encapsulation dot1Q 40
no cdp enable
bridge-group 40
bridge-group 40 subscriber-loop-control
bridge-group 40 spanning-disabled
bridge-group 40 block-unknown-source
no bridge-group 40 source-learning
no bridge-group 40 unicast-flooding
interface Dot11Radio0.50
encapsulation dot1Q 50
no cdp enable
bridge-group 50
bridge-group 50 subscriber-loop-control
bridge-group 50 spanning-disabled
bridge-group 50 block-unknown-source
no bridge-group 50 source-learning
no bridge-group 50 unicast-flooding
interface Dot11Radio1
no ip address
encryption vlan 10 key 1 size 40bit 7 E1E65A9502DE transmit-key
ssid HOUSE-Net
ssid HOUSE_Guest
ssid MAN
antenna gain 0
peakdetect
dfs band 3 block
stbc
mbssid
channel width 80
channel dfs
station-role root
interface Dot11Radio1.10
no cdp enable
bridge-group 10
interface Dot11Radio1.20
no cdp enable
bridge-group 1
interface Dot11Radio1.30
no cdp enable
bridge-group 30
interface Dot11Radio1.40
no cdp enable
bridge-group 40
interface GigabitEthernet0
no ip address
duplex auto
speed auto
interface GigabitEthernet0.10
description Management Trunk
no cdp enable
bridge-group 10
interface GigabitEthernet0.20
description Home_Network trunk
no cdp enable
bridge-group 1
interface GigabitEthernet0.30
description IoT Trunk
no cdp enable
bridge-group 30
interface GigabitEthernet0.40
description Guest Trunk
no cdp enable
bridge-group 40
interface GigabitEthernet0.50
no cdp enable
bridge-group 50
interface GigabitEthernet1
no ip address
duplex auto
speed auto
bridge-group 1
interface BVI1
mac-address 188b.9d8c.daac
ip address 10.20.20.52 255.255.255.0
ipv6 address dhcp
ipv6 address autoconfig
ipv6 enable
ip default-gateway 10.20.20.55
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip ssh version 2
ip radius source-interface BVI1
no cdp run
radius-server local
nas 10.20.20.52 key 7 passwdxxxx
group Management
block count 10 time 3
reauthentication time 10
user josy nthash 7 xxxxxxxxxxxxxxxxxxxxxxxx
user Gabe nthash 7 xxxxxxxxxxxxxxxxxxxxxxxx group Management
user tim nthash 7 xxxxxxxxxxxxxxxxxxxxxxxx
user Zach nthash 7 xxxxxxxxxxxxxxxxxxxxxxxx
radius-server attribute 32 include-in-access-req format %h
radius server AP3-client
address ipv4 10.20.20.52 auth-port 1812 acct-port 1813
key 7 passwdxxxx
bridge 1 route ip
wlccp ap username Gabe password 7 xxxxxxxxxxxxxxxxxx
wlccp ap wds ip address 10.20.20.54
line con 0
line vty 0 4
transport input ssh
line vty 5 15
transport input ssh
end
