Access-point 1131G registration issues on Wireless controller over Layer3 transport mode.
pankaj_cisco111
There are set of 1131G access points which belong to different segment  than management couldn’t be registered on Wireless Controller (Catalyst 6509 WISM). However access points allocated in same range of management network is easily registering on controller. I have created AP-Manager interface which allowing Dynamic AP-Management. Once I’m creating dynamic interface on Controller which pointed to Layer3 interface of APs vlan, the controller starts deducting those access points as not-joined APs  and displaying following messages. Please suggest.
Lwapp discovery request rejected.
Layer 3 discovery request not received on management VLAN.
Surendra BG
Hi Pankaj,
Here is the bug ID..
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCti54658
Please create a seperate Dynamic interafce and then see what happens as per the bug work around..
lemme know if this answered your question..
Surendra
Please dont forget to rate the post which answered your question or was usefull
Surendra BG
Hi Surendra,
Problem still exists. It starts giving above error after creating separate dynamic interface for APs. Access-points join statistics simply disappear once I remove dynamic interface.
Pankaj
So that means you have configured DHCP option 43 as well? if we have seperate Dynamic interface?
Surendra
Surendra BG
Hi Pankaj,
can you please post a "show interface summary" of your Wism so that we can see clearer and also explain in which subnet are the problematic APs.
Nicolas
