access points joining problem
khaled masri
dear all,
kindly note, cisco access points not joined, I received the following logs from the WLC 2504
#DTLS-3-HANDSHAKE_FAILURE: openssl_dtls.c:2963 Failed to complete DTLS handshake with peer 192.168.198.101
the access points getting IP correctly from the Core Switch, also note tries this command without any luck :
config ap lifetime-check mic enable
any solution for that problem ???
7 Replies 7
Mark Elsen
        - What are the access point models ? What is the controller software version ?
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
access points: AIR-CAP1702I-E-K9 software version 15.3(3)JA5
WLC software Version 8.0.121.0
 - You need at least 8.3.x on the controller, then you can use these commands :
                   config ap cert-expiry-ignore  mic enable
                   config ap cert-expiry-ignore   ssc enable
 M.
Adjust the date of the WLC back to two years and then reboot the AP.
Sandeep Choudhary
Can you paste the complete bootup logs from AP console:
also paste the output of the command from WLC: show sysinfo
khorram1998
Level 4
Level 4
This error message is indicating that the DTLS (Datagram Transport Layer Security) handshake between the access point and the wireless controller is failing. This can be caused by a number of different factors, including incorrect time synchronization, certificate issues, or issues with the network configuration.
Here are a few steps you can try to troubleshoot and resolve the problem:
  1. Verify that the time on the access point and the wireless controller is synced correctly. The DTLS handshake is time-sensitive, and if the clocks are not in sync, it can cause the handshake to fail.
  2. Check the certificate configuration on both the access point and the wireless controller. Ensure that the correct certificate is installed and that it is not expired or otherwise invalid.
  3. Confirm that the network settings, such as IP addresses and subnet masks, are configured correctly on both the access point and the wireless controller.
  4. Check the security settings of the network, verify that the same security settings are being used on both the access point and the wireless controller.
  5. Try restarting both the access point and the wireless controller, and see if this resolves the issue.
  6. Run the command show ap debug dtls, this will show the DTLS packet exchange between the AP and the WLC to see where the failure is happening.
  7. Double check the AP's firmware, if the AP is running different version than the WLC, upgrade the AP to the same version as the WLC.
  8. If none of the above steps solve the problem, you may need to contact Cisco Technical Support for further assistance.
    All the best,
    AK
Rich R
If you really must run 8.0 then at least update to https://software.cisco.com/download/home/283848165/type/280926587/release/8.0.152.0 which will also support the commands @Mark Elsen mentioned. Follow all the steps in the field notice 63942 linked below carefully.  You need to set the time back as Leo said to allow the APs to join then download the software and config.  After that you can turn NTP on again.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
