Access Points unable to Join Wireless Controller
Jameztee
Visitor
My access points are unable to Join the Wireless controller. It looks like the following:
Anyone have an idea how to fix this? Please help....
srimal99
Level 5
Level 5
@Jameztee  as @balaji.bandi  always good practice to post WLC mode and code version along with ap model.
Community help guide :
https://community.cisco.com/t5/security-knowledge-base/how-to-ask-the-community-for-help/ta-p/3704356
5 Replies 5
ammahend
there can be many reasons, you should provide more information like WLC SW, HW version, AP model, AP logs, debugs etc
anyways go through this link, this has potential reasons why AP wont join controller, you can investigate following the process in the documentation and let the community know what you find, there is a good change you will find the problem and fix it using this documentation
https://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/119286-lap-notjoin-wlc-tshoot.html
-hope this helps-
Thank you, this is very helpful.
balaji.bandi
As asked valid questions, what is WLC Model and Code running, what Model of the AP.
In addition to that, is this AP joined to WLC before ?
Do you have any other AP join WLC ?
can you connect the Console cable to AP and check what is wrong - by rebooting the AP ?
is the Port up on the Switch side and got enough power to AP ?
BB
srimal99
Level 5
Level 5
Rich R
And it goes without saying that you should make sure your software version is up to date as per the TAC recommended link below.  Currently older models like 2504, 5508, 8510 should be running 8.5.182.12 (link below) and newer models like 3504, 5520, 8540 should be running 8.10.196.0.  Also check against the Compatibility Matrix (link below) for the AP models you're using.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
