Hi Guys
I have some indoor AP's configured and running on with my WLC 5520
now I'm trying to configure my outdoor AP's to the same but it doesn't seem to work.
WLC ver 8.5.161
AP ver 8.5.140.0
im getting the following when i console to the AP
CRIT-MeshLink: Set Root port Mac: C4:B2:39:55:C3:6A BH Id: 0 Port:0 Device:DEVNO_WIRED0
[*08/05/2020 07:32:59.1974] CRIT-MeshLink: Notify Capwap Link Up: mac: C4:B2:39:55:C3:6A BH Id: 0 GW_reachable: No Roam: false
[*08/05/2020 07:32:59.1990] driver_wpas: - wpa_driver_wpas_init
[*08/05/2020 07:33:04.0021] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*08/05/2020 07:33:04.0026] Discovery Response from 129.16.4.11
[*08/05/2020 07:33:04.0081] ethernet_port wired0, ip 129.16.5.79, netmask 255.255.254.0, gw 129.16.4.10, mtu 1500, bcast 129.16.5.255, dns1 8.8.8.8, domain wlanmgmt.com, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*08/05/2020 07:33:04.1259] AP IPv4 Address updated from 129.16.5.76 to 129.16.5.79
[*08/05/2020 07:33:13.0000] can't find the Ip from discoveryRequest array
[*08/05/2020 07:33:13.0001]
[*08/05/2020 07:33:13.0001] CAPWAP State: DTLS Setup
[*08/05/2020 07:33:13.3726]
[*08/05/2020 07:33:13.3726] CAPWAP State: Join
[*08/05/2020 07:33:13.3740] Sending Join request to 129.16.4.11 through port 5264
[*08/05/2020 07:34:10.0178] CAPWAP State: DTLS Teardown
[*08/05/2020 07:34:14.8730]
[*08/05/2020 07:34:14.8730] CAPWAP State: Discovery
[*08/05/2020 07:34:14.8741] IP DNS query for CISCO-CAPWAP-CONTROLLER.wlanmgmt.com
[*08/05/2020 07:34:15.2361] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*08/05/2020 07:34:15.2367] Discovery Response from 129.16.4.11
[*08/05/2020 07:34:25.0000] can't find the Ip from discoveryRequest array
[*08/05/2020 07:34:25.0001]
[*08/05/2020 07:34:25.0001] CAPWAP State: DTLS Setup
[*08/05/2020 07:34:25.3713]
[*08/05/2020 07:34:25.3713] CAPWAP State: Join
[*08/05/2020 07:34:25.3726] Sending Join request to 129.16.4.11 through port 5264
Solved! Go to Solution.
Hi guys
thanks for the support
I was able to rectify this issue I wasn't aware that for outdoor type AP's
I need to provide the MAC address of AP on the WLC for authentication
once added the connection was made automatically.
It would be nice if it is visible in the AP's console log so that we know we have to add the MAC address instead of keep on retying to connect.
- Check compliance requirements (between controller/AP/software versions) with :
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
M.
Hi guys
Can you please post a link to the document which describes how to register the AP MAC on the 5520?
