AIR-LAP1142N-N-K9 down frequently
Tony WONG
We have 12 APs (AIR-LAP1142N) connecting with controller 5508
One of the APs is always down
Tue Jun 8 10:01:24 2021 AP Disassociated. Base Radio MAC:24:b6:57:ae:c3:50
4 Tue Jun 8 10:01:24 2021 AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:24:b6:57:ae:c3:50 Cause=Max Retransmission Status:NA
Tue Jun 8 09:39:01 2021 AP's Interface:1(802.11a) Operation State Up: Base Radio MAC:24:b6:57:ae:c3:50 Cause=Reset on transmit completion. Status:NA
2 Tue Jun 8 09:38:58 2021 AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:24:b6:57:ae:c3:50 Cause=Reset on transmit completion. Status:NA
41 Tue Jun 8 09:29:50 2021 AP's Interface:1(802.11a) Operation State Up: Base Radio MAC:24:b6:57:ae:c3:50 Cause=Indicates that while the radio state should be updated on controller, no reset should be reported. Status:NA
Not sure what's going wrong.  Other 11 APs are OK.
Controller 5508 v7.4.150
IOS 15.2(2)JB6$
marce1000
 - Both controller model and AP's are old (including the  current software version being used on  the controller) , last supported version for the 1142N is 8.3.x , try that version on the 5508.
 M.
patoberli
Does the issue disappear after a restart of the AP? If not and it's only that one, it might have a broken radio.
Tony WONG
upgrade from 7.4 to 8.0 and reset of the AP, it still has lots of up and down from this AP in office hours.
Broken radio?   Should i give it up?
I wouldn't spend to much time into this old AP. If needed, you might cheaply get them on Ebay or similar.
