AP not joining Controller
singh7881
Visitor
I have a Cisco 3700 Series AP and trying to connect it to a WLC 5508. I have getting a certificate validation failed error, however when I use the command "show crypto pki certificates" no such expired certificate shows up. Previously had an issue with certificate on this AP, and I made it so that the WLC ignores expiry of certificates through the CLI.
*Mar 1 00:01:19.167: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*May 10 14:52:36.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.27.10.5 peer_port: 5246
*May 10 14:52:38.235: %PKI-3-CERTIFICATE_INVALID_EXPIRED: Certificate chain validation has failed. The certificate (SN: 1468F48300000002CF39) has expired. Validity period ended on 00:51:11 UTC Apr 26 2024Peer certificate verification failed 001A
*May 10 14:52:38.235: %CAPWAP-3-ERRORLOG: Certificate verification failed!
*May 10 14:52:38.235: DTLS_CLIENT_ERROR: ../capwap/base_capwap/capwap/base_capwap_wtp_dtls.c:467 Certificate verified failed!
*May 10 14:52:38.235: %DTLS-5-SEND_ALERT: Send FATAL : Bad certificate Alert to 172.27.10.5:5246set_radio_pwr_mode: bad radio unit# 0
set_radio_pwr_mode: bad radio unit# 1
10 Replies 10
Mark Elsen
 - FYI :: https://www.cisco.com/c/en/us/support/docs/field-notices/639/fn63942.html
                  What software version is the 5508 running ?
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
It is running version 8.0.140.0
8.0.140.0 will not work reliably without constant workarounds being applied.  You obviously have not read the field notices below - please do so without further delay?
You need to update to 8.5.182.11 (link below) and apply the config for expired certs as per Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration  You will need to set the WLC time back to allow the AP to join and download new software and config.  After that you can re-enable NTP for correct system time.
Before you update to 8.5.182.11 check the compatibility matrix (link below) to make sure all your AP models will still be supported on the new version.
If you don't update the software you'll just be wasting time trying to resolve these issues.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Hi Rich, thanks for this solution. I will try to apply it as soon as possible. @jagan.chowdam asked me to find the Cisco SHA1 device cert certificate in the WLC and I can see that it expired on the date shown in the logs in my original post. One thing I am wondering though is why is that only 1 AP was affected? All our other APs are also Cisco 3700 Series. If a certificate in the WLC has expired shouldn't it affect all APs?
Some of the x700 APs had SHA1 certs and some had SHA2 certs depending on when they were manufactured and that means they behave differently when handling certificates.
jagan.chowdam
Please refer the Field Notice: https://www.cisco.com/c/en/us/support/docs/field-notices/639/fn63942.html
And follow the Workaround/Solution mentioned.
You have AirOS Controller 5508. Use command and look for Cisco SHA1 device cert entry
show certificate all
Jagan Chowdam
/**Pls rate useful responses**/
jeremiah.cox2
Level 2
Level 2
I had success in temporarily rolling the system date back on the controller as the certificate on the AP was expired. Spent several hours on with TAC before we discovered this. NTP will adjust the date/time on next poll though so as soon as that AP loses connectivity it wont connect again. Ultimately we upgraded our APs and Controllers.
Da fuq?  Several hours???
We are all volunteers in this forum.  None of us work for Cisco TAC but @Mark Elsen & @jagan.chowdam have provided the right answer/solution within 45 minutes after this thread went up.
Rich R
The solution for anyone else reading this is to upgrade the 5508 to 8.5.182.11 (link below) and read through all the field notices below carefully to make sure you've applied all the configuration required to deal with expired certs.
This is a very well known problem so it should have taken TAC about 2 minutes to diagnose this!  The fact that it took hours reflects on the quality of many first line TAC staff these days.
Note that both WLC and AP certs can expire so even if AP cert has not expired, very old WLCs like 5508 may also have expired certs.  This is covered in the field notices.
 @Rich R >...The fact that it took hours reflects on the quality of many first line TAC staff these days.
                                    We are the best!
 M.
