Cisco 3504 DCA problem
teckchai-chong
Frequent Visitor
Frequent Visitor
Hi Guys,
I have face a very weird issue. Currently my environment are running with 2 x C3504 in HA. There have 18 AP mixed with 1702, 1852, 2802, 9120. Some support for CleanAir some not. Too use all this model, we had choose the version 8.10.130. So far everything is working good. But there have one funny thing is the DCA assign all my AP in channel 11. Same to the 5Ghz (All AP in same channel).
Those AP is not that far from each others, it should be within 10 meter radius. I had try to off the DCA, and manual channel/ power, it work perfectly in signal coverage. But when i turn on the DCA, the power will be like 6-8 (-70dBm to -75dBm) and all stick with same channel.
May i have some clue that what i should looking into the configuration?  Thank in advance.
5 Replies 5
Mark Elsen
                - FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvn76866
    Go for https://software.cisco.com/download/home/286312601/type/280926587/release/8.10.190.0
    and check if that can bring improvement
                          >...May i have some clue that what i should looking into the configuration?
   You may for instance have a checkup of the controller configuration using WirelessAnalyzer input (procedure) for AireOs controllers
   and feed the output from that into Wireless Config Analyzer
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
teckchai-chong
Frequent Visitor
Frequent Visitor
I had try to diagnose, i think my current environment does not meet the RRM critirial. I have multiple AP (More than 3 neighbours AP) but all the signal is less than -65dBm. That make the thing into a bad cycle. I try to reboot all AP, but the AP boot up power is not 1. Hence when RRM cannot detect or meet the critirial, there are no changes in channel. Now the envrinoment are running smooth although all in Channel 11, no roaming issue, speed and coverage also quick good. No error found.
May i know does Cisco Catalyst/ Aironet AP boot up, the initial channel is 11 right? Is that the reason why all my channel is stick to 11?
jagan.chowdam
Have you tried restart DCA from WLC CLI?
2.4 GHz: config 802.11b channel global restart
5 GHz: config 802.11a Channel global restart
Make sure you selected all 2.4Ghz non overlapping channels (1,6 & 11) under DCA Channel list.
Jagan Chowdam
/**pls rate useful responses**/
Yes, the DCA are restart, can see the channel update time. But the Channel is still all 11. I had try manual configure the channel, it work nothing different from now, just the power assignment txPower might higher only. I am just thinking is that the bug or it is just balance and i can just leave it within co-channel.
Rich R
Did you read @Mark Elsen reply?
1. Upgrade to 8.10.190.0 as per TAC recommended (link below)
2. Check your WLC config using Config Analyzer (link below).  Rectify all errors reported by the tool (in red).
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
