C9120 AP Not Joining C9800-L-F-K9 WLC (DTLS Handshake Expired)
viraj patil
Hello Team,
we have replaced 90 access points till now and they connected as well with WLC. But for 02 access points, it's giving the error of "DTLS Handshake expired". Please help to resolve this issue.
WLC Model = C9800-L-F-K9
AP Model = C9120AXE & C9120AXI
WLC Version = 17.3.6
6 Replies 6
balaji.bandi
Hope i take this as new AP ?
Can you do Factory reset and try to re-join
Also connect console cable and post complete boot logs here to understand the issue ?
what Version of AP - is some mode of the AP shipping later 2022 (i dont remember) need new code 17.9.4a on WLC ( also suggest to upgrade to new code on WLC is advised all the time for better bug fixes)
check some filed notice :
https://www.cisco.com/c/en/us/support/docs/field-notices/639/fn63942.html
https://www.cisco.com/c/en/us/support/docs/field-notices/724/fn72424.html
BB
marce1000
              - Go for  17.9.4a  = recommended release ,
 M.
Scott Fella
Here is a nice guide to help with ap's not joining issues:
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/218396-troubleshoot-catalyst-9800-ap-join-or-di.html
-Scott
Rich R
If the APs have old version of software installed they might not be able to join to the WLC.
As others have said upgrade WLC to TAC recommended version as per the link below.
You might also need to upgrade the AP software manually before it can join - for 17.3.6 that would be 15.3(3)JPJ9:
https://software.cisco.com/download/home/286322988/type/286288051/release/15.3.3-JPJ9
alaangaldino
Follow the procedure for correction
For AP Models 2802, 3802, 4800, 9105, 9115, 9120
  1. While connected to the console, power cycle the AP.
  2. During bootup, when you see Hit ESC key to stop autoboot, press the Escape key
  3. This should bring you to (u-boot)> prompt.
  4. Run these commands
(u-boot)> ubi part fs
(u-boot)> ubi remove part1 (or part2 if corrupted image is in part2)
(u-boot)> ubi create part1 (or part2 if corrupted image is in part2)
(u-boot)> boot
@alaangaldino those instructions are only relevant if the active software partition is corrupted - which should not be the case with a new AP.  And in that case those instructions alone may not be enough to guide the user to resolving the issue.  Those instructions are copied from the technote at https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/220443-how-to-avoid-boot-loop-due-to-corrupted.html and should be read as part of the entire technote for full understanding of the issue, and the resolution, and the alternative methods for resolving it - if corrupted active partition is the root cause of the problem.  Note the link to the technote is already included in the links in my signature on my previous reply above.
