Catalyst 9800 rommon mode
nstr1
I have a problem with my Catalyst 9800 L-C.
My 9800 had some configurations then i decided erase that config with the command factory-reset all
Later my 9800 reboot but when my 9800 started i can see my 9800 in rommon mode.
i wastrying initializar with diferent commands but even the command Dir showed this;
rommon24>dir
Incorrect Usage
Also i was trying initializar from an USB but it was impossible;
rommon4>dir usb0:
File system not supported
Also i was tryaing to used this guide
https://www.routexp.com/2019/05/cisco-wireless-controller-password.html
but i could not initializar my 9800.
What happen with my 9800??
15 Replies 15
nstr1
When my 9800 starts it shows this;
Initializing Hardware ...
System Bootstrap, Version 16.12(3r), RELEASE SOFTWARE
Copyright (c) 1994-2019 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: LocalSoft
The values of MSR 0x198h = 00001400 and MSR 0x199h = 00001400 for KATAR
C9800-L-X-K9 platform with 16777216 Kbytes of main memory
no valid BOOT image found
Final autoboot attempt from default boot device...
boot: cannot determine first file name on device "bootflash:"
autoboot: boot failed, restarting...
rommon1
balaji.bandi
make sure USB formatted with  File System: FAT32   ( that is the best option is USB or you can try TFTP)
i prefer USB with 8GB  stick,
here is the guide :
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/214012-recovering-a-catalyst-9800-controller-fr.html#anc6
BB
I was trying with that guide but was impossible.
Here the results;
rommon11>
rommon11>confreg 0x2142
You must reset or power cycle for new config to take effect
rommon12>sync
rommon13>reset
Resetting .......
rommon1>
You need to boot from USB image.
make sure you follow the steps in the document,  dir usb0:  is the key to see if the files are there
BB
Yes i was trying too,
I connected my USB (my USB is FAT32) and show this;
rommon15>
rommon15>dir usb0:
rommon16>
Even i couldn´t execute only dir becaouse show this;
rommon24>dir
Incorrect Usage
is this USB 3.0 ?
Load image through USB
Step 1. Have a USB pen drive with the .bin file to be loaded to the 9800 controller (on 9800-80, due to CSCvn82287
, a USB 3.0 flash drive may not be recognized in ROMMON).
post  outout
dir bootflash:
then try TFTP method other option as per the URL i have provided
BB
I don't think that USB is FAT32.  Like @balaji.bandi said use a 8Gb USB drive and make sure it is *really* FAT32.  If it's larger then Windows tends to use exFAT by default but may still report it as FAT32.
https://www.geeksforgeeks.org/difference-fat32-exfat-ntfs-file-system/
Format it from a command prompt and specify the fileystem format to use.
/FS:filesystem Specifies the type of the file system (FAT, FAT32, exFAT,NTFS, UDF, ReFS).
Or use whichever tool or utility you prefer but make 100% sure it is really FAT32.
What is the brand/make and the size of this USB stick?
Cisco routers and switches will only support up to 16 Gb size.
My usb is 1.0 and it is only 4gb
CSCvn82287 is irrelevant in this case anyway.  If it was that it would say "media drive usb0: not present" but it's not - it's saying "File system not supported" which is why I refer back to my previous reply on making sure it is actually FAT32?
Regarding bug descriptions - like Leo says they can be wildy inaccurate or misleading sometimes - we've asked for them to be updated with correct info a number of times.
So have you reformatted the drive definitely using FAT32?
Otherwise just use TFTP.
Try get another USB as suggest and try and let us know. or you can use TFTP to resolove quicker.
BB
This bug, CSCvn82287, should be made "private" because it is so inaccurate:  I have several Samsung- and Toshiba-branded USB 3.0 thumb drives (various Toshiba "models") and they work on IOS-XE in ROMMON flawlessly.
And this is one example why I always take Bug IDs information with hesitation because they more-than-usual lack "accuracy".
Scott Fella
Make sure that the conf reg is correct. Earlier versions were set wrong causing the 9800-L to boot into rommon
confreg 0x2142
-Scott
Leo Laohoo
Post the complete output to the following commands:
dir flash:
set
