Cisco Air-Cap2602i-A-k9 error loop and no exec access
fernoadmin
We had an AP a while back just stop working and started giving this constant loop of CAPWAP errors. We tried to do a factory reset by unplugging, holding the MODE button, and reconnecting power while holding the button until the light turned. This did change the name of the AP to it's mac address but that is about all it did.
We still are getting this constant loop of CAPWAP errors and any commands we put in to change the CAPWAP config come back with the "command disabled" message. What is going on with this AP and what can we do about it?
The following is all of the AP info and the error messages we are receiving:
   AP Info:
     Cisco IOS Software C3600 (AP3G2-K9W8-M) Version 12.4(25e)JA Release Software (fc1)
     Cisco AIR-CAP3602I-A-K9
     PowerPC Processor (rev A0)
     LWAPP image Version 7.2.103.0
     Config Register is 0xF
   Errors:
     *Mar 30 21:36:28.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.1.1.11:5246
     *Mar 30 21:36:29.063: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
     *Mar 30 21:36:29.063: bsnInitRcbSlot: slot 0 has venus radio(UNSUPPORT)
     *Mar 30 21:36:29.063: bsnInitRcbSlot: slot 1 has venus radio(UNSUPPORT)
     *Mar 30 21:36:29.063: bsnInitRcbSlot: Slot 1 has same radio type as slot 0. Disabling radio in slot 1.
     *Mar 30 21:36:30.079: bsnUnlockDevice: not bring radio up: radio 0 is in admin disable state
     *Mar 30 21:36:30.079: bsnUnlockDevice: not bring radio up: radio 1 is in admin disable state
     *Mar 30 21:36:30.079: status of voice_diag_test from WLC is false
     *Mar 30 21:36:40.079: %CAPWAP-3-ERRORLOG: Go join a capwap controller
     *Mar 30 21:36:40.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.1.11 peer_port: 5246
     *Mar 30 21:36:40.455: %CAPWAP5-DTLSREQSUCC:DTLS connection created sucessfully peer_ip:10.1.1.11 peer_port: 5246
     *Mar 30 21:36:40.455: %CAPWAP-5-SENDJOIN: sending Join Request to 10.1.1.11
     *Mar 30 21:36:45.455: %CAPWAP-5-SENDJOIN: sending Join Request to 10.1.1.11
Any help would be greatly appreciated. We are a small company and really need every bit of hardware we have to work for us.
Thanks in advance!
FernoAdmin
23 Replies 23
IOS Bootloader - Starting system.
flash is writable
FLASH CHIP: Numonyx Mirrorbit (0089)
Xmodem file system is available.
flashfs[0]: 65 files, 7 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31997952
flashfs[0]: Bytes used: 15697920
flashfs[0]: Bytes available: 16300032
flashfs[0]: flashfs fsck took 16 seconds.
Reading cookie from SEEPROM
Base Ethernet MAC address: 30:f7:0d:29:0b:6e
Ethernet speed is 1000 Mb - FULL Duplex
Loading "flash:/ap3g2-k9w8-mx.153-3.JF12/ap3g2-k9w8-mx.153-3.JF12"...#########################
File "flash:/ap3g2-k9w8-mx.153-3.JF12/ap3g2-k9w8-mx.153-3.JF12" uncompressed and installed, entry point: 0x2003000
executing...
Secondary Bootloader - Starting system.
Tide MB - 32MB of flash
flashfs[0]: flashfs fsck took 8 seconds.
flashfs[1]: 0 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 12257280
flashfs[1]: Bytes used: 1024
flashfs[1]: Bytes available: 12256256
flashfs[1]: flashfs fsck took 1 seconds.
2600/3600 AP, PID: 'AIR-CAP3602I-A-K9 '. Checking for BL upgrade...
BL: C3600 Boot Loader (AP3G2-BOOT-M) LoaderVersion 12.4(23)JY, RELEASE SOFTWARE (fc1)
Compiled Thu 03-Oct-13 03:35 by sdcunha
BL Build year: 13
Unable to locate IOS image with name **xx**.
Boot CMD: 'boot flash:/ap3g2-k9w8-mx.153-3.JF12/ap3g2-k9w8-xx.153-3.JF12'
Loading "flash:/ap3g2-k9w8-mx.153-3.JF12/ap3g2-k9w8-xx.153-3.JF12"...###################################################
File "flash:/ap3g2-k9w8-mx.153-3.JF12/ap3g2-k9w8-xx.153-3.JF12" uncompressed and installed, entry point: 0x1003000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C3600 Software (AP3G2-K9W8-M), Version 15.3(3)JF12, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Mon 17-Feb-20 22:50 by prod_rel_team
Initializing flashfs...
flashfs[2]: 65 files, 7 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 31739904
flashfs[2]: Bytes used: 15697920
flashfs[2]: Bytes available: 16041984
flashfs[2]: flashfs fsck took 10 seconds.
flashfs[2]: Initialization complete.
flashfs[4]: 0 files, 1 directories
flashfs[4]: 0 orphaned files, 0 orphaned directories
flashfs[4]: Total bytes: 11999232
flashfs[4]: Bytes used: 1024
flashfs[4]: Bytes available: 11998208
flashfs[4]: flashfs fsck took 0 seconds.
flashfs[4]: Initialization complete.
Copying radio files from flash: to ram:
Copy in progress...CCCCC
Copy in progress...CCCCCCCC
Uncompressing radio files...
...done Initializing flashfs.
Radio0 present 8764 8000 0 A8000000 A8010000 0
timeout waitin for fw ready
nop failed
*Mar 1 00:00:14.871: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (15)
*Mar 1 00:00:58.227: %SYS-5-RELOAD: Reload requested by Init. Reload Reason:
Radio FW image download failed ....
Did you upload the "ap3g2-rcvk9w8-tar.153-3.JK1.tar" file to the AP?
No I initially labeled this as 2600 series but as you can tell from the config it’s a 3600. I went to Cisco’s website and downloaded the image for the air-cap3602i-a-k9. That was ap3g2-k9w8-mx.153-3.JF12.tar
That is not going to fix the issue.
In ROMMON, post the complete output to the following commands:
dir flash:ap3g2-rcvk9w8-mx
I can't seem to get in rommon. I have been using the same usb to rj45 cable since the beginning, but every since I flashed that image when I try to send a break signal; I looked up all the break signal keyboard combinations on cisco just to try others,and none of them seem to work. It just continues loading and never enters ROMMON. I tried on a separate computer  and I tried with multiple applications (screen on mac, teraterm and putty on windows). I do have a separate serial to usb converter that I tried as well and that didn't work either (Was only able to try this cable on windows as it doesn't seem to work on mac). I ordered another cable but the initial one I was using was brand new so I'm not sure that is going to work either.
marce1000
 https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvb25644/?rfs=iqvred
 M.
That's what I figured the issue was, but I can't seem to get into ROMMON now. When the image is inflating I hit Esc and nothing happens. I have also tried TeraTerm (Alt-B) and several other keyboard shortcuts I found in cisco forums, none of them will get me into ROMMON. It's almost as if it doesn't sense that I am sending a break signal. How should I go about diagnosing why this is happening?
You can also power the AP on while holding the Mode button. Keep it pressed until the message appears that the mode button is pressed + (I think) 7 seconds. Then you should land in ROMMON. If the message "Mode button stuck" (or similar) appears, you pressed to long and need to repeat it.
