Cisco Switch not detecting Access Point
BGH
 I have a Ruckus AP model H320 (Mac: 7047.7726.67b0) connected directly to my Cisco Catalyst 2960 > Port Gi0/5
But due to some reason the switch does not detect the Access point.
SW-R506#show mac address-table address 7047.7726.67b0
Mac Address Table
Vlan Mac Address Type Ports
SW-R506#show mac address-table interface gigabitEthernet 0/5
Mac Address Table
SW-R506#show int status
Port Name Status Vlan Duplex Speed Type
Gi0/1 PHONE_523 connected 1102 a-full a-100 10/100/1000BaseTX
Gi0/2 RAP_523 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/3 AP_521 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/4 PHONE_524 connected 1102 a-full a-100 10/100/1000BaseTX
Gi0/5 RAP_524 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/6 RAP_521 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/7 PHONE_521 connected 1102 a-full a-100 10/100/1000BaseTX
Gi0/8 AP_527 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/9 notconnect 1100 auto auto 10/100/1000BaseTX
Gi0/10 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/11 notconnect 1 auto auto Not Present
Gi0/12 notconnect 1 auto auto Not Present
SW-R506#show running-config interface gigabitEthernet 0/5
Building configuration...
Current configuration : 232 bytes
interface GigabitEthernet0/5
description RAP_524
switchport trunk allowed vlan 80,102,103,250,500,504,510,535,550,1100,1102
switchport trunk allowed vlan add 1103,1107
switchport mode trunk
no ip igmp snooping tcn flood
end
On Port Gi0/3 we have a different AP connected and this AP is detected and working
SW-R506#show mac address-table interface gigabitEthernet 0/3
Mac Address Table
504 5698.5e56.31a3 DYNAMIC Gi0/3
504 de7f.55be.b590 DYNAMIC Gi0/3
535 c808.7322.0060 DYNAMIC Gi0/3
Total Mac Addresses for this criterion: 3
We tried resetting the AP mutliple
Changed the eth cable
Restarted the port Gi0/5
We also tried different port Gi0/9
But same issue
SW-R506#show mac address-table interface gigabitEthernet 0/9
Mac Address Table
Here below is the configuration from Port Gi0/3 where a different AP works fine
And also the configuration from Port Gi0/5 and Gi0/9
SW-R506#show running-config interface gigabitEthernet 0/3
Current configuration : 200 bytes
interface GigabitEthernet0/3
description AP_521
end
SW-R506#show interfaces gigabitEthernet 0/3
GigabitEthernet0/3 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 002f.5cf5.1403 (bia 002f.5cf5.1403)
Description: AP_521
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:09, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 74
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 438000 bits/sec, 59 packets/sec
5 minute output rate 1702000 bits/sec, 416 packets/sec
1087647534 packets input, 2535496395098 bytes, 0 no buffer
Received 15194605 broadcasts (8372078 multicasts)
3 input errors, 3 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 8372078 multicast, 57376725 pause input
42538219979 packets output, 36022442849564 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
description RAP_524
end
SW-R506#show running-config interface gigabitEthernet 0/9
Current configuration : 240 bytes
interface GigabitEthernet0/9
switchport access vlan 1100
end
SW-R506#show interfaces gigabitEthernet 0/5
GigabitEthernet0/5 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 002f.5cf5.1405 (bia 002f.5cf5.1405)
Description: RAP_524
Last input 5w2d, output 00:00:00, output hang never
5 minute output rate 183000 bits/sec, 245 packets/sec
6251454500 packets input, 2096714402437 bytes, 0 no buffer
Received 201320456 broadcasts (158352070 multicasts)
0 watchdog, 158352070 multicast, 0 pause input
64633761578 packets output, 25528716832912 bytes, 0 underruns
0 output errors, 0 collisions, 9 interface resets
SW-R506#show interfaces gigabitEthernet 0/9
GigabitEthernet0/9 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 002f.5cf5.1409 (bia 002f.5cf5.1409)
MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
Keepalive not set
Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
Last input never, output never, output hang never
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
We are pretty much sure that the AP does not have any issue because this is a new AP sent from the vendor and we also tried some spare APs but the result is same.
Can someone check the configuration and advise please.
21 Replies 21
Leo Laohoo
I've seen this hundreds of times (different PD) -- The port is "pulling power" but there is no MAC address.
The AP has crashed.
So you confirm that the issue is with the AP.
No, YOU have to confirm the issue with the AP.
Rich R
@BGH don't you need to set native VLAN on the switch port for the Ruckus management VLAN?
Have you enabled LLDP on the switch: globally "lldp run" and on the switch port which is usually on by default?
This is a working switch port config (C1000-24P-4G-L running 15.2(7)E7) with a Ruckus H350 AP:
interface GigabitEthernet1/0/1
 description <your description>
 switchport trunk native vlan XXX
 no cdp enable
 spanning-tree portfast edge trunk
 spanning-tree bpdufilter enable
 spanning-tree bpduguard disable
end
GigabitEthernet0/9 is down, line protocol is down (notconnect) <<- this L1 issue
the line is down and protocol is also down
as Mr. Leo mention this issue of AP crashed not config
let wait his reply
MHM
@MHM Cisco World the question was about the Ruckus AP connected to Gi0/5:
> "I have a Ruckus AP model H320 (Mac: 7047.7726.67b0) connected directly to my Cisco Catalyst 2960 > Port Gi0/5"
From his post
But same issue
MHM
