Wireless
review
Labels
HI I have a customer asking why Cisco does not manufacture an extension cable for use between native DART-8 APs such as the 9174e and native DART-8 Octal Dart antenna such as the C-ANT9102 of more than 3m i.e. the AIR-CAB003-D8-D8=.Can I assume this ...
sbcoms by • Community Member
  • 9 Views
  • 0 replies
Hello, colleagues! I deployed the WLC 9800 on ESXi, transferred the access point 9105AXI to a lightweight one with the command "ap-type capwap".But then a problem arose: the access point receives its IP from DHCP (15 VLAN), the controller sees it, bu...
burich96 by • Spotlight
  • 24792 Views
  • 6 replies
A Plan's afoot to change the name of my wlc stacks.  My guess is while the CLI execution is effortless, I don't think the system will update all the Primary controller names but since the AP does an ip relink or a DNS call out to Cisco Capwap Control...
i need to add another ssid to a prod 3802 but i keep getting the error message below. i thought i had fixed it 20 minutes ago but adding QUS_VMS_VLAN991/991 (Configuration, Tags & Profiles, Flex, QUS-Flex-Profile, VLAN tab). can someone tell me what ...
KeCheng by • Community Member
  • 211 Views
  • 3 replies
Running two 9800-L-F-K9 in HA with the version 17.18.04a.I have the same status. #show telemetry ietf subscription all% Error: Internal error - failed to create GREEN response#show platform software yang process stateProcess Status       Statepubd   ...
JR-AG-2024 by • Frequent Visitor
  • 142 Views
  • 2 replies
Hello everyone. We have a deployment of 26 MR 46, the equipment are connected to several switches Catalyst, the issue is the user report that they felt high latency in the network, they are working ok, but suddenly the network becomes slow, even they...
Hey guys , i would be happy if someone helped me in this drag and drop question,  the problem is in the "it requires ip addresses on ap and WLC".  i   read in a cisco documentation that  layer 2 lwapp still requires ip addresses  on WLC and ap, so i ...
Please advise and give me your opinion:I need to perform a ROMMON upgrade from version 17.7(3r) to 17.12(1r) on a C9800-40. The guides say that I must use the command reload and not reload slot x, which means both WLCs will restart, not just the one ...
