Cisco WLC 9800-CL Flexconnect mode with Vlan group
Cheah Lit Thor
I have a 9800-CL Wireless Controller running with Flex connect mode,  i have a question on how can i apply the function like previous Air OS Cisco wireless controller "interface group" to 9800-CL Flex connect mode?
Isn't this the same as AireOS?  If the ap is defined for FlexConnect local switching, interface groups is not supported?  If you locally switch, then interface groups or vlan groups is supported.
-Scott
Jegan Rajappa
Vlan group replaces interface group in 9800 IOSXE WLAN controller
I found an information from documentation Flex connect restriction portion as attach.
for example If my scenario in flex connect environment my user SSID "Y" assign with Vlan 401 in Policy Profile facing insufficient of ip address assignment to users and i try to create another Vlan and group it in Vlan group assign in Policy Profile, however in flex profile seem doesn't supported Vlan group function so may I know any alternative solution can work on it?
thanks
-Scott
