cisco wlc 9800 ha configuration issue
CCC3
cisco wlc 9800
In version 17.3.6
I have set up HA
There is no response even if I remove Active's uplink.
However, if the corresponding port is shotdown from the cli, Active will pass normally.
is this a bug?
marce1000
  -  Review the 9800   configuration  first with the CLI command : show  tech   wireless , have the output analyzed by  https://cway.cisco.com/tools/WirelessAnalyzer/  , please note do not use classical show tech-support (short version) , use the command denoted in green for Wireless Analyzer.               Checkout all advisories!
 M.
balaji.bandi
We are not clear on the below points :
There is no response even if I remove Active's uplink.   - You mean Active WLC Uplink ?  what kind of deployment is Central or Local switching ?   Is WLC have a port-channel? what logs do your see on the console?
When you remove the uplink : what is the out put from active WLC
#show interface status (do you see the Link go down)
# show chasis
# show redundancy
again we need to look above mentioned output to understand, this might have failed over ?
Some references and checks :
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213915-configure-catalyst-9800-wireless-control.html
BB
Rich R
@balaji.bandi has given you good guidance there.
Make sure you have gateway monitoring enabled https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-3/config-guide/b_wl_17_3_cg/m_vewlc_high_availability.html#id_109520
Based on the limited info you've provided I'm going to guess:
- not port-channel
- not using gateway monitoring
- interface possibly misconfigured so that fibre disconnect is not detected.
So back to first principles - why isn't your interface going down when you pull the fibre?
You didn't mention the WLC model but make sure ROMMON and PHY are up to date as per:
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/214749-tac-recommended-ios-xe-builds-for-wirele.html#anc47
