Conversion of .dwg format
fabianoleso
I am using Location Appliance 2700 Serie, and I must import a plant in WCS.
According to "Cisco 2700 Series Wireless Location Appliance - Deployment Guide", the only two importable formats are: .jgps and .bmps.
I have a plant in .dwg format.
Can somebody help me to convert my format .dwg into either .jgps or .bmps ?
Thank you!!!
5 Replies 5
gpulos
Level 8
Level 8
please see the following link for a good .DWG to JPG conversion utility: (this is shareware so there is no up front costs)
http://www.canadiancontent.net/tech/download/DWG_to_JPG_Converter.html
there are many more on the net. search the net for '.dwg conversion to .jpg'.
ethiel
Level 3
Level 3
If you have AutoCad available, you can output it to jpg directly from AutoCad. If not, Visio is an option, as well as one of the many free utilities out there. Some co-workers of mine have used AnyDwg (anydwg.com), but there are many fine tools out there.
I would suggest a search of google for "+convert +dwg +jpg" to gegt a few potential programs. Most offer a trial period to see if you like them. If this is a one time conversion, a trial might be all you need.
Thank you so much!!!!!
wwiedemann
Please find nConvert download or go to: http://perso.orange.fr/pierre.g/xnview/enhome.html. This is a free application that handles over 400 different file formats and converts them. I used this to convert the AutoCAD .dwg files to .jpg for my Wireless Control System maps.
dagyb
I used this: http://anydwg.com/ you can buy it or just use the free trial.
