copy run start not a valid command ?
nflnetwork
Level 4
Level 4
hello we have just booted up a cisco Aironet 3802I (AIR-AP3802I-A-K9) access point. i've connected using SSH and logged in.
there is no copy run start cli command from what i can tell?
What am I missing here? (feeling very stupid)
cisco AIR-AP3802I-A-K9 ARMv7 Processor rev 1 (v7l) with 1028584/648876K bytes of memory.
Processor board ID FJC24386S0RAP Running Image     : 8.5.140.0Primary Boot Image   : 8.5.140.0Backup Boot Image    : 0.0.0.0
1 Multigigabit Ethernet interfaces
1 Gigabit Ethernet interfaces
2 802.11 Radios
Radio Driver version : 9.0.5.5-W8964
Radio FW version : 9.1.8.1
NSS FW version : 2.4.25
balaji.bandi
is the AP running Autonomously or Lightweight?
BB
Arshad Safrulla
you are right, copy run start is not there in 3802 APs running in capwap mode. If you want to manage the AP locally you need to install or convert it to Mobility express. (mini-WLC on the AP itself) Links are as below;
Cisco Mobility Express Deployment Guide - Conversion [Cisco 5500 Series Wireless Controllers] - Cisco
Convert a Cisco CAPWAP AP to a Mobility Express AP – SemFio Networks
Rich R
I think @Arshad Safrulla has probably answered your question for you but to elaborate a bit more:
copy run start is a Cisco IOS command.  The last APs to run Cisco IOS were the Wave 1 AC models 1700/2700/3700 etc.
From the Wave 2 AC (1800/2800/3800) models all Cisco AP run a new operating system called Cisco AP-COS also referred to as simply COS or ClickOS.  So this is not IOS anymore.  There are a few CAPWAP commands which have been kept the same but the rest are gone or changed.
copy run start would only make sense on an IOS AP running autonomous (k9w7) IOS.  In the Wave 2 APs autonomous AP does not exist anymore.  Mobility Express (as described by Arshad above) is the replacement for that.  The AP runs a virtual WLC on itself and the AP joins its own virtual WLC to run standalone, similar to autonomous (requires 1 IP address for the AP and 1 IP address for the WLC).  All configuration for the AP is done on the WLC not the AP itself.  The WLC runs AireOS (cut-down version) the same as the older WLCs (2500/5500/8500).
In the WiFi 6 Catalyst 9100 series (AX) APs Mobility Express was replaced by Cisco Embedded Wireless Controller (EWC) for AP which is based on the 9800 series IOS-XE WLCs.  Again it runs on the AP in the same way as ME and all config for the AP is done on the WLC.  EWC is more full-featured than ME but still has limitations due to running on AP hardware.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
