Could power off the Aironet 1130 status LED?
raymond.chuang
We had a Aironet which needs to installed on dark room but its status LED always blink. Could we turn off the LED by configure? As I knew this AP can be configured continuously blinking the status LED.
There is no way that I know of to turn off the leds. The only hidden command is one that allows you to blink them from the cli and change the duration of each but it will not stop them. Electrical tape over the leds is probably your only option.
nhabib
Level 9
Level 9
Access the AP via a browser and go to System Software -> System Configuration
There should be an option there for Blink the Access Point LEDs
Thank, that is for LED blink.But, we need to turn off the "Status LED".
