Default route configuration
Tricon
Hello Folks,
I am following this guide:
https://www.cisco.com/c/en/us/support/docs/lan-switching/inter-vlan-routing/41860-howto-L3-intervlanrouting.html
I have successfully configured a C3750X switch into a few Vlans, one of which is hosting an Aironet 1142. The C3750 provides IP addresses via DHCP through the Aironet to a client.
I have a router connected to port 48 of the switch
  • The router can ping the switch
  • The switch can ping the router
The client can ping the switch in the 192.168.110.x and 192.168.120.x subnets.
The client can ping the switch port connected to the router 192.168.101.250.
The client cannot ping the router interface. I do not know why. I have tried both a routeable and Vlan based interface between the switch and the router.
Neither of these options work - ping fails from client to router (but works to last hop on switch).
eg:
Tracing route to 192.168.101.250 over a maximum of 30 hops
1   2ms   2ms  3ms  192.168.101.250
If someone could suggest where I need to look to be able to route from the WiFi client to the router it would be appreciated.
Thank you.
Switchy#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.101.1 to network 0.0.0.0
C    192.168.120.0/24 is directly connected, Vlan20
C    192.168.110.0/24 is directly connected, Vlan10
C    192.168.101.0/24 is directly connected, Vlan1
S*   0.0.0.0/0 [1/0] via 192.168.101.1
C    192.168.101.0/24 is directly connected, GigabitEthernet1/0/48
VLAN Name                             Status    Ports
1    default                          active    Gi1/0/37, Gi1/0/38, Gi1/0/39
                                                Gi1/0/40, Gi1/0/41, Gi1/0/42
                                                Gi1/0/43, Gi1/0/44, Gi1/0/45
                                                Gi1/0/46, Gi1/0/47, Gi1/0/48
                                                Gi1/1/1, Gi1/1/2, Gi1/1/3
                                                Gi1/1/4
10   vlan10                           active    Gi1/0/1, Gi1/0/2, Gi1/0/3
                                                Gi1/0/4, Gi1/0/5, Gi1/0/6
                                                Gi1/0/7, Gi1/0/8, Gi1/0/9
                                                Gi1/0/10, Gi1/0/11, Gi1/0/12
20   vlan20                           active    Gi1/0/13, Gi1/0/14, Gi1/0/15
                                                Gi1/0/16, Gi1/0/17, Gi1/0/18
                                                Gi1/0/19, Gi1/0/20, Gi1/0/21
                                                Gi1/0/22, Gi1/0/23, Gi1/0/24
30   vlan30                           active    Gi1/0/25, Gi1/0/26, Gi1/0/27
                                                Gi1/0/28, Gi1/0/29, Gi1/0/30
                                                Gi1/0/31, Gi1/0/32, Gi1/0/33
                                                Gi1/0/34, Gi1/0/35, Gi1/0/36
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
10   enet  100010     1500  -      -      -        -    -        0      0
20   enet  100020     1500  -      -      -        -    -        0      0
30   enet  100030     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    -        0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trnet 101005     1500  -      -      -        ibm  -        0      0
Remote SPAN VLANs
Primary Secondary Type              Ports
1    default                          active    Wl0/0, Gi0/1/0, Gi0/1/1, Gi0/1/2
                                                Gi0/1/3, Gi0/1/4, Gi0/1/5
                                                Gi0/1/6, Gi0/1/7
50   VLAN0050                         active
1    enet  100001     1500  -      -      -        -    -        1002   1003
50   enet  100050     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        1      1003
1003 tr    101003     1500  1005   0      -        -    srb      1      1002
1004 fdnet 101004     1500  -      -      1        ibm  -        0      0
1005 trnet 101005     1500  -      -      1        ibm  -        0      0
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is not set
      192.168.101.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.101.0/24 is directly connected, GigabitEthernet0/0
L        192.168.101.1/32 is directly connected, GigabitEthernet0/0
Pool vlan10 :
 Utilization mark (high/low)    : 100 / 0
 Subnet size (first/next)       : 0 / 0
 Total addresses                : 254
 Leased addresses               : 1
 Excluded addresses             : 14
 Pending event                  : none
 1 subnet is currently in the pool :
 Current index        IP address range                    Leased/Excluded/Total
 192.168.110.4        192.168.110.1    - 192.168.110.254   1     / 14    / 254
add the below static route to your RouterR1:
--> ip route 192.168.110.0 255.255.255.0 GigabitEthernet0/0
34 Replies 34
Georg Pauwen
post the running configurations (sh run) of both the router and the switch. What is the IP address of the client you are trying to ping from ?
Thanks, Georg.
The IP address of the client machine I am using is:
192.168.110.10/24
Default Gateway is 192.168.110.1
Switch config:
Building configuration...
Current configuration : 7286 bytes
version 12.2
no service pad
hostname Switchy
boot-start-marker
boot-end-marker
enable secret 5 **********
enable password **********
no aaa new-model
switch 1 provision ws-c3750x-48p
system mtu routing 1500
ip routing
ip dhcp excluded-address 192.168.110.1
ip dhcp excluded-address 192.168.110.250
ip dhcp excluded-address 192.168.110.251
ip dhcp excluded-address 192.168.110.252
ip dhcp excluded-address 192.168.110.253
ip dhcp excluded-address 192.168.110.254
ip dhcp excluded-address 192.168.101.1
ip dhcp excluded-address 192.168.101.2
ip dhcp excluded-address 192.168.120.1
ip dhcp excluded-address 192.168.120.2
ip dhcp excluded-address 192.168.110.3
ip dhcp excluded-address 192.168.110.4
ip dhcp excluded-address 192.168.110.5
ip dhcp excluded-address 192.168.110.6
ip dhcp excluded-address 192.168.110.7
ip dhcp excluded-address 192.168.110.8
ip dhcp excluded-address 192.168.110.9
ip dhcp pool vlan10
   network 192.168.110.0 255.255.255.0
   dns-server 1.1.1.3 1.0.0.3
   default-router 192.168.110.1
crypto pki trustpoint TP-self-signed-2029314176
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2029314176
 revocation-check none
 rsakeypair TP-self-signed-2029314176
crypto pki certificate chain TP-self-signed-2029314176
 certificate self-signed 01
  quit
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
 no ip address
 no ip route-cache cef
 no ip route-cache
 shutdown
interface GigabitEthernet1/0/1
 switchport access vlan 10
 switchport mode access
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
 switchport access vlan 20
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
 switchport access vlan 30
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface Vlan1
 ip address 192.168.101.250 255.255.255.0
interface Vlan10
 ip address 192.168.110.1 255.255.255.0
interface Vlan20
 ip address 192.168.120.1 255.255.255.0
interface Vlan30
 ip address 192.168.130.1 255.255.255.0
ip default-gateway 192.168.101.1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.101.1
ip route 192.168.101.0 255.255.255.0 192.168.101.1
ip http server
ip http secure-server
snmp-server community public RO
line con 0
 exec-timeout 0 0
line vty 0 4
 password **********
 login
line vty 5 15
 password **********
 login
end
Router Config
Current configuration : 2675 bytes
! No configuration change since last restart
version 15.2
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone SYDNEY 10 0
service-module wlan-ap 0 bootimage autonomous
no ipv6 cef
ip name-server 8.8.8.8
ip name-server 1.1.1.1
ip cef
license udi pid CISCO1941W-N/K9 sn **********
hw-module ism 0
redundancy
controller VDSL 0/0/0
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 192.168.101.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
 duplex auto
 speed auto
 no mop enabled
interface wlan-ap0
 description Service module interface to manage the embedded AP
 no ip address
 arp timeout 0
 no mop enabled
 no mop sysid
interface GigabitEthernet0/1
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
interface Wlan-GigabitEthernet0/0
 description Internal switch interface connecting to the embedded AP
 no ip address
 shutdown
interface ATM0/0/0
 no ip address
 shutdown
 no atm ilmi-keepalive
interface Ethernet0/0/0
 no ip address
 shutdown
interface GigabitEthernet0/1/0
 no ip address
 shutdown
interface GigabitEthernet0/1/1
 no ip address
 shutdown
interface GigabitEthernet0/1/2
 no ip address
 shutdown
interface GigabitEthernet0/1/3
 no ip address
 shutdown
interface GigabitEthernet0/1/4
 no ip address
 shutdown
interface GigabitEthernet0/1/5
 no ip address
 shutdown
interface GigabitEthernet0/1/6
 no ip address
 shutdown
interface GigabitEthernet0/1/7
 no ip address
 shutdown
interface Vlan1
 no ip address
 shutdown
ip forward-protocol nd
ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 x.x.x.x 254
ip route 0.0.0.0 0.0.0.0 dhcp
dialer-list 1 protocol ip permit
snmp-server enable traps entity-sensor threshold
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line 67
 no exec
 transport input all
line vty 0 4
 password **********
 login
 transport input all
scheduler allocate 20000 1000
ntp server 132.163.97.5
end
Thanks, Georg
[sorry this appeared to go missing]
The configuration of the client machine is:
IP 192.168.110.10/24
Gateway 192.168.110.1
Switch Configuration is:
version 12.2
no service pad
hostname Switchy
boot-start-marker
boot-end-marker
no aaa new-model
ip routing
ip dhcp pool vlan10
  quit
 no ip address
 no ip route-cache
 shutdown
interface Vlan1
interface Vlan10
interface Vlan20
interface Vlan30
ip classless
ip http server
line con 0
 exec-timeout 0 0
line vty 0 4
 password **********
 login
line vty 5 15
 password **********
 login
end
Router:
version 15.2
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip cef
hw-module ism 0
redundancy
 no ip address
 shutdown
 ip nat inside
 duplex auto
 speed auto
 no mop enabled
interface wlan-ap0
 no ip address
 arp timeout 0
 no mop enabled
 no mop sysid
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
 no ip address
 shutdown
interface ATM0/0/0
 no ip address
 shutdown
 no ip address
 shutdown
 no ip address
 shutdown
 no ip address
 shutdown
 no ip address
 shutdown
 no ip address
 shutdown
 no ip address
 shutdown
 no ip address
 shutdown
 no ip address
 shutdown
 no ip address
 shutdown
interface Vlan1
 no ip address
 shutdown
ip http server
control-plane
line con 0
line aux 0
line 2
 no exec
 transport input all
 stopbits 1
line 67
 no exec
 transport input all
line vty 0 4
 password **********
 login
 transport input all
end
Hi Georg,
It appears that my replies are being lost.
Client address is:
GW 192.168.110.1
Switch Config
version 12.2
no service pad
hostname Switchy
boot-start-marker
boot-end-marker
no aaa new-model
ip routing
ip dhcp pool vlan10
  quit
 no ip address
 no ip route-cache
 shutdown
interface Vlan1
interface Vlan10
interface Vlan20
interface Vlan30
ip classless
ip http server
line con 0
 exec-timeout 0 0
line vty 0 4
 password **********
 login
line vty 5 15
 password **********
 login
end
looks like it...if you cannot attach the configs (sh run) then just paste them in...
I'll try again...(3rd time...)
version 12.2
no service pad
hostname Switchy
boot-start-marker
boot-end-marker
no aaa new-model
ip routing
ip dhcp pool vlan10
quit
no ip address
no ip route-cache
shutdown
interface Vlan1
interface Vlan10
interface Vlan20
interface Vlan30
ip classless
ip http server
line con 0
exec-timeout 0 0
line vty 0 4
password **********
login
line vty 5 15
password **********
login
end
version 15.2
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip cef
hw-module ism 0
redundancy
no ip address
shutdown
ip nat inside
duplex auto
speed auto
no mop enabled
interface wlan-ap0
no ip address
arp timeout 0
no mop enabled
no mop sysid
ip address dhcp
ip nat outside
duplex auto
speed auto
no ip address
shutdown
interface ATM0/0/0
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
interface Vlan1
no ip address
shutdown
ip http server
control-plane
line con 0
line aux 0
line 2
no exec
transport input all
stopbits 1
line 67
no exec
transport input all
line vty 0 4
password **********
login
transport input all
end
Switch Config
version 12.2
no service pad
hostname Switchy
boot-start-marker
boot-end-marker
no aaa new-model
ip routing
ip dhcp pool vlan10
  quit
 no ip address
 no ip route-cache
 shutdown
interface Vlan1
interface Vlan10
interface Vlan20
interface Vlan30
ip classless
ip http server
line con 0
 exec-timeout 0 0
line vty 0 4
 password **********
 login
line vty 5 15
 password **********
 login
end
I'll try to attach.
what is the IP address of the client you are pinging from ?
