DNAC wireless error message exceeded threshold and utilization
nathanmonteyne0
Hi All,
So I was wondering if anyone can help me out with this.
there are a lot of tickets being generated by DNAC with the following.
The 5GHz radio on the AP [ap name] has exceeded the 85% threshold and is currently experiencing 86% utilization. This is impacting [amount] client(s).
the threshold and utilization is different everytime and also the AP is different everytime
Rich R
What model of AP and what version of software is it (and the WLC) running?
There are a number of bugs which can cause this so you need to make sure your software is up to date to resolve those.  See TAC recommended link below.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
JPavonM
Start by checking why such high utilization on the radios on the WLC.
If it is in 2.4 GHz one, consider there are lot of transmitters using this band, if it is on 5-GHz band, check what could be happening, and if it's only on certain channels.
Rich R
