Guest WLAN client not able to get IP from DHCP
Sharath Karpur
Dear All,
I have a strange situation, WLAN clients not able to get IP address from DHCP pool and not getting authenticated
- WLC Interface which are used by other WLAN works well, clients gets IP address and works well.
- Same WLAN configuration works well across the globe. only on this controller clients fail to get ip address.
- Model : 5508 ( HA )
- Version: 8.5.140
- I did the Client debug and attaching logs. - please help guys.
-client mac address : 34:02:86:b9:76:bb
Sharath
patoberli
Do you have the VLAN 608 on that WLC configured and also reachable?
Or is anything else specially configured for 'SAS-Default'?
*apfMsConnTask_3: Oct 12 01:28:35.182: [PA] 34:02:86:b9:76:bb Applying Local Bridging Interface Policy for station 34:02:86:b9:76:bb - vlan 608, interface id 12, interface 'guest', nasId:'CHIA09'
*apfMsConnTask_3: Oct 12 01:28:35.182: [PA] 34:02:86:b9:76:bb override from ap group, removing intf group from mscb
*apfMsConnTask_3: Oct 12 01:28:35.182: [PA] 34:02:86:b9:76:bb Applying site-specific override for station 34:02:86:b9:76:bb - vapId 15, site 'SAS-Default', interface 'guest'
HI,
Vlan 608 is reachable and SAS-default is the AP group and required SSID is
added.
Actually I solved the issue as there was mac filtering enabled in WLAN and
in security tab > mac filtering > Free Radius was enabled ! as results WLC
and radius key was exchanging for mac authentication, I felt that was bad
and changed it to Cisco ACS and it was through.
Sharath
