Help! Bridge wireless intermittent
RubinoM
Community Member
I installed two br350.
Every 18 minutes (circa) the link go down.
Log from non-root "Lost authentication with parent"
then "Deauthenticating [root bridge], reason "not autenticated"
then "Associated to Parent"
This loop go away for 7-10 times, then the link go up for other 18 minutes, then the loop start again.
please help me, thanks.
PS Excuse me for my english
9 Replies 9
soechsle
Community Member
Check your CCA value - if set to default 62 - you must set it to something other than default. Set to 61 or 60. There is an open caveat on that issue - has to do with noise signal ratio or something like that.
The CCA problem only applies to IOS. BR350 runs VxWorks.
dixho
Level 11
Level 11
How do you connect the antenna and 350 bridge? (i.e. connect one of the ports or both ports)
If you connect only one port, you need to set the antenna from diversity to right (or left).
i.e.
1. click on "Setup" in the GUI
2. click on "Hardware" beside Radio
3. Check the Receive and transmit Antenna
RubinoM
Community Member
I have already done it.
Fist I thought that it was a visibily problem, so I moved the antenna; but the situation has not changed.
I wonder why this problem happened every 18 minutes.
thanks very much
ROBERT CROOKS
Level 2
Level 2
I have exactly the same problem, with the same equipment. I changed the antennas to the primary(right) and so far the problem has not re-occured (the disconnection).
Will continue to monitor and see how this goes.
When the bridge link is active, what is the signal strength to the non-root bridge?
Click "Associations"
Click the MAC Address of the non-root bridge.
Go down and look for "Latest signal strength"
If it's really low, you need to realign. How far apart are the bridges and what kind of antenna are you using?
RubinoM
Community Member
I'm using two bridges 350 with yagi 13,5 dBi antennas. The distance is 1,5 Km.
The antennas is just primary (right).
Now I can't see the signal strength, but Tuesday I'll see it.
In your opinion, why the disconnections are periodically, with this kind of regolarity?
Which version of the VxWorks OS are you using?
We found that only version 12.03T & above are stable for outdoor deployment.
The initial 12.0x releases (including version 12.00 that shipped with the unit) suffer from link stability issue similar to your situation.
I have a similar intermittent link issue with 1242APs used as RootAP/Workgroup bridge combination. The user does not perceive the Radio link going down and up, because the recovery is pretty fast.
As can been seen in the logs below, the reason is max retries exceeded. Is there a way, we can improve the situation? or is this normal?
Moreover, my link tests show higher SNR a max of 254 in one direction. The other way around, it is low.. How do i interpret these results...?
Any help is appreciated.
Apr 10 12:56:56.720: %DOT11-6-ADD: Interface Dot11Radio0, Station 0001.02dc.c97b
Associated to Parent 0014.1ced.367e
Apr 10 12:56:59.350: %DOT11-4-MAXRETRIES: Packet to client 0014.1ced.367e reache
d max retries, removing the client
Apr 10 12:56:59.635: %DOT11-6-ADD: Interface Dot11Radio0, Station 000d.562b.d7cb
Apr 10 12:56:59.649: %DOT11-6-ADD: Interface Dot11Radio0, Station 000d.562c.0932
Apr 10 12:56:59.658: %DOT11-6-ADD: Interface Dot11Radio0, Station 0001.02dc.c97b
Apr 10 13:03:05.088: %DOT11-4-MAXRETRIES: Packet to client 0014.1ced.367e reache
Apr 10 13:03:05.088: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
Station 0014.1ced.367e Reason: Previous authentication no longer valid
Apr 10 13:03:10.295: %DOT11-6-ASSOC: Interface Dot11Radio0, Station NewGate 0014
.1ced.367e Reassociated KEY_MGMT[NONE]
Apr 10 13:03:10.309: %DOT11-6-ADD: Interface Dot11Radio0, Station 000d.562b.d7cb
Apr 10 13:03:10.319: %DOT11-6-ADD: Interface Dot11Radio0, Station 000d.562c.0932
Apr 10 13:03:10.325: %DOT11-6-ADD: Interface Dot11Radio0, Station 0001.02dc.c97b
Apr 10 13:42:44.805: %DOT11-4-MAXRETRIES: Packet to client 0014.1ced.367e reache
Apr 10 13:42:44.805: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
Apr 10 13:42:44.901: %DOT11-6-ASSOC: Interface Dot11Radio0, Station NewGate 0014
Apr 10 13:42:44.927: %DOT11-6-ADD: Interface Dot11Radio0, Station 000d.562c.0932
Apr 10 13:42:44.932: %DOT11-6-ADD: Interface Dot11Radio0, Station 0001.02dc.c97b
FAIR (24 % retries) Time Strength(dBm) SNR SNR Retries
msec In Out In Out In Out
Sent : 100, Avg 5 - 91 - 92 3 7 Tot: 11 38
Lost to Tgt: 0, Max 18 - 90 - 90 8 254 Max: 4 4
Lost to Src: 0, Min 2 - 94 - 95 0 0
Rates (Src/Tgt) 2Mb 75/75 5.5Mb 25/25
Linktest Done
Link test results from the AP at the other end configured as Workgroup bridge.
Linktest Done
FAIR (16 % retries) Time Strength(dBm) SNR SNR Retries
Sent : 100, Avg 3 - 90 - 90 8 5 Tot: 26 6
Lost to Tgt: 0, Max 9 - 88 - 89 255 9 Max: 4 4
Lost to Src: 0, Min 2 - 93 - 92 0 1
Rates (Src/Tgt) 5.5Mb 100/100
Linktest Done
