help : no SSID + A slot down...
bouchal-38
I just configured 2 new AP:
AIR-LAP1262N-E-K9
and i did the configuration just like my 60 others (most of them are AIR-LAP1042N-E-K) and on those one i can not see the SSID, also, in the 'interface' tab i have 1 slot down, what does it mean?I don't think it is normal compare to my other?
slot 0: 802/b/g/n Admin Stat: Disable, oper Stat: Down ...
see attached file
Any idea?
Tx,
B
Erwin Salazar
Judging from the attachment, it looks like the Slot 9 802.11b/g/n radio is Admin 'Disabled' state, meaning it was somehow manually disabled.  All you would simply need to do is set this back to 'Enabled' to bring it up.  You can do this through Wireless > Access Points > 802.11b/g/n.  Scroll to the far right for your AP in question and hover over the small blue box > Select Configure.  You should be able to set the Admin Status here.
Cheers, Erwin ______________________________________ How helpful was I? Don't forget to rate me when you have the chance!
Amjad Abdullah
I second Erwin. Check the admin state of the radio and set it to enabled rather than disabled.
Rating useful replies is more useful than saying "Thank you"
Abhishek Abhishek
As per your query i can suggest you the following link to refer for setup guide-
http://www.cisco.com/en/US/docs/wireless/access_point/1260/quick/guide/ap1260getstart.html
Hope this will help you.
