how to check that antennas are connected to access point?
Andrey128
Which command(s) can show whether antennas are connected to access point and to which transmitter on access point (2.4 Ghz vs 5Ghz)?
If found that #show controllers d0 or d1 gives this output
Antenna: external, Gain: Allowed 4, Reported 4, In Use 4
However the result looks not always correct. (sometimes controller without antenna showed the same as with antenna).
Please give advise(s).
Leo Laohoo
No command available.  The output of the "sh controllers" is statically assigned and can be changed manually.
