- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
08-05-2015 03:31 AM - edited 07-05-2021 03:42 AM
Hello all,
Recent past I had purchased one CISCO( AIR-CAP3702I-D-K9 ) AP. yes I understand that default it is a controller based AP.
I wanted to convert it into Autonomous AP. can anybody help me ?
1. What is the software(IOS) version is need for particular model ?
2. From where I can download ?
3. what will be the default IP Address of the CISCO AP ?
Kishore
Solved! Go to Solution.
- Labels:
Aironet Access Points
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-13-2015 04:47 AM
15.3.3-JBB1 is Autonomous AP IOS Software for 3702i download file ap3g2-k9w7-tar.153-3.JBB1.tar from here
http://www.cisco.com/c/en/us/support/wireless/aironet-3700i-access-point/model.html#~tab-downloads
by default Cisco AP is set to received IP address from DHCP . console to AP and show interface bvi1 should show you details
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-05-2015 03:35 AM - edited 12-23-2017 02:08 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-05-2015 06:45 AM
Hello Kishore
I would recommend you to see the below community posts which is answered related to your issue.
https://supportforums.cisco.com/document/58026/lwapp-mode-autonomous-mode-conversion
https://supportforums.cisco.com/discussion/9893911/ligthweigth-mode-autonomous
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-17-2015 11:14 PM
Hello Prakash,
Thanks for the response that you provided to me on my problem.
the correct and exact solution is for my particular model i.e 3702i model follow below link. it worked fine.
http://www.chainringcircus.org/cisco-3702-lightweight-to-autonomous-conversion/
Kishore
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-18-2015 01:02 AM
Thank you Kishore for sharing the solution .
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-13-2015 04:47 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-22-2015 06:30 AM
Hello Venkatesh,
I had followed the steps which you mentioned and downloaded ios/image(ap3g2-k9w7-tar.153-3.JBB1) as mentioned in your previous post.
Please find the attached console log, I have few queries .
1. In your post stated that after finishing the reboot go to web GUI and configure the AP? what will be the IP address after flashing ?
2. But I am sure my flashing is not been success because
#"sh ver" is showing :
AP84b8.02a0.f31c uptime is 37 minutes
System image file is "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx"
Last reload reason:
#downloaded version:
could you please conform me that flashing has been successful ?
3. I could see one line keep on appearing on console. as mentioned below.
*Mar 1 00:02:34.179: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
NOTE: AP 3702i newly purchased and it wasn't connected with controller during the flashing using tftpd32.
Thanks for the help in advance....
4. I could see there are many release 15.3.3-JBB5, 15.3.3-JBB, 15.3.3-JAB 15.3.3-JBB1 may I know why can't I use the latest image from CISCO downloads?
Kishore.
