How to Expand Wireless Signals Strenth
canceevsat
Dear Sir,
Please guide me how I can expand up my Signals ?
I am receiving signals from my upstair room
I need to be expand these via an antenna or any thing ,Please guide me how I can be.
http://cancee.com/vpn/Signals.JPG
Hammad
22 Replies 22
ccbootcamp
Level 7
Level 7
Sure, you can stick an amplifier on each side, or a bigger antenna (or a more directional antenna with a higher DB gain).
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
Dear Sir,
These Signals are Not Directional ,these are comming from normal DSL Router Modem,i.e Linksys,Netgear,
So I need some Antenna or some Range Expander which will work for me from all sides Like I will fix it with my PCI LAN Card and it will boost my signals.
What Lan Card I am useing Please see here .
My PCI CARD
http://www.dlink.com/products/?pid=306
My Friends DSL modem .
http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1149562300349&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=0034939789B02
Thanks for your reply,
Hammad
Get a better antenna for your PC. That will make a HUGE difference.
You could also put a better antenna on the AP.
-brad
www.ccbootcamp.com
To Connect an AP I think We must have to have a UTP cable ,and then I have to connect this .
Well Ok AP is Ok but tell me I need to boost up my signals without touching my friends pc or modem how can it is possible .
One of my Friend say that you have to buy a AP and then you will fix as Repeater and for this you have to know your Friends SSID and WEP key I say Ok I have all these things ,
But after this he say for this you have to Plug UTP cable in your Friends Modem this is so far from me as you see in picture ,And he say without touching my Pc if you can get more signals then Ok !
So AP will not work when you dont have any modem or router in Backbone.
Hammad
Try getting a better antenna for your PC. See if that solves your issue.
Check out this link (it has some options posted):
http://www.hdcom.com/links.html
-brad
www.ccbootcamp.com
Dear Sir ,
I am not useing any thing like Directional antenna, The sgianls are comming Omni type did you see ?
2nd I am sure that from your side what remarks I will get that will work 1000% and I dont want to make any experiment I need some 10000% advice or guideline .
So tell me now What I have to do ?
Hammad
GET A BETTER ANTENNA FOR YOUR PC. Get a bigger omni. Good luck!
Yes Ofcourse but which one Every one knows this Plane going to US but your Ticket no one Pay :)
Well Sir Which model what Brend Please give all information Is it Ok see link below.?
Thanks so much.
Hammad
http://sa.netgear.com/Products/APsWirelessControllers/AntennasandCables/ANT2409.aspx
Yeah, that one looks like a winner to me! That should definitely increase your range.
Please make sure and rate all my posts.
Have a great one!
Brad
Thanks so much for your support,
Well one of my friend just send me this Device link pleae have a look and tell me whcih one is good for me as you see I have poor low signals.
Please chk which one I may Chose.
http://www.ruckuswireless.com/products/metroflex/
Or
Or
http://sa.netgear.com/Products/APsWirelessControllers/AntennasandCables/ANT24O5.aspx
Please clearify which one is BEST in RANG.
Thx.
Hammad
My choice:
I dont know anything about the metroflex unit.
-brad
www.ccbootcamp.com
laurentElens
Yes indeed, an antenna adapted to your physical situation , a good site survey, cisco material (A.P., adapter and software [if properly configured]) are some of the paths to a better reception.
No I try buy yesterday an Antenna but no good success .
What I can do Please see Improvements.
Hammad
First of all guys we need to look at the root problem here. The wireless dsl router is probably of retail quality meaning it has a low powered radio with poor receive sensitivity. Compound that with the use of a poor client adapter (laptop) and you have a recipe for poor signal. Power doesn't equal quality of signal. You could increase the power ten fold and if the quality is still bad then the connection will be poor. Buy an enterprise class acess point, enable diversity (for multipath issues) and get a good quality network adapter for the PC. This will solve 90% of connectivity issues. If you still have problems look at the drivers configuration for your laptop card.
