Issues with 9800-L CLI Access
mumbles202
Level 7
Level 7
Consoled into a 9800 today, created a new user, then logged into the GUI and did the Day 0 configuration.  Reconnected to the GUI and was able to do a good bit of the configuration from there; I also tried to ssh to the WLC and enter some configuration, but even though "enable" was listed when I entered "?" at the > prompt, when I try to enter it was a command I get a message "Error in Authentication".  I was able to use the CLI portion of the GUI to enter the configuration I needed to, but wanted to see if there was a reason for response and being unable to get into the CLI.
7 Replies 7
balaji.bandi
From GUI you are able to use CLI, so post-show run here (check anything changed on the vty lines)
how about ssh ?
BB
mumbles202
Level 7
Level 7
Looking at the exported configuration I think I see the issue.  During the Day 0 wizard I added a Radius server that I intended to use for 802.1x for 1 of the WLANs but I think the controller also might be using that for logins as well.  Shouldn't the controller fail-back to local authentication if the server isn't reachable or isn't responding (I put in a dummy password during the wizard).
yes it should if configured correctly AAA with radius and local- (since we are dark on the config - I am afraid to comment)
BB
Totally understood.  Here's the aaa configuration:
aaa new-model
aaa group server radius RADIUS_SERVER_GROUP_DAY0
 server name RADIUS_SERVER_DAY0_1
aaa group server radius RAD_GRP_ACCT_POL
aaa group server radius RAD_GRP_ACCT_POL_PROF
aaa authentication login authentication_login_day0 group RADIUS_SERVER_GROUP_DAY0
aaa authentication dot1x authentication_dot1x_day0 group RADIUS_SERVER_GROUP_DAY0
aaa authentication dot1x DOT1X_AUTH_MYSSID group RADIUS_SERVER_GROUP_DAY0
aaa authorization network MAB_LOCAL_AUTH_Testing local
aaa accounting identity ACCT_LIST_POL_ start-stop group RAD_GRP_ACCT_POL
aaa accounting identity ACCT_LIST_POL_PROF start-stop group RAD_GRP_ACCT_POL_PROF
aaa attribute list wlan_lobby_access
aaa server radius dynamic-author
aaa session-id common
radius server RADIUS_SERVER_DAY0_1
 address ipv4 192.168.1.10 auth-port 1812 acct-port 1813
 timeout 5
 retransmit 5
I was able to figure this out; was just missing an enable password.  Once I added that the command took and I was able to get into privileged mode from cli.
glad you able to resolve the issue, we mark as resolved now.
BB
Rich R
You should probably have a read through https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/214490-configure-radius-and-tacacs-for-gui-and.html
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
