Mobility Express Client roaming issue
Deepak Kumar
Hi All,
I am facing some issue that clients are getting dropped during the roaming. Here are some primary logs:
 MESSAGE_RECEIVED
AAA_MESSAGE_CREATION_FAILED
MESSAGE_RECEIVED
ASSOC_REQ_RECEIVED
MESSAGE_RECEIVED
MESSAGE_RECEIVED
ASSOC_REQ_RECEIVED
MESSAGE_RECEIVED
MESSAGE_RECEIVED
MESSAGE_RECEIVED
WLAN_REQUIRES_802_1X_AUTH
PACKET_SENT_TO_CLIENT
WEB_AUTH_MAX_RETRY_EXCEEDED
ADDING_WGB_CLIENT
CALL_TERMINATED
CALL_DURATION
WEB_AUTH_FAILED
WEB_AUTH_SUCCESS
IP_ADDR_CLEARED
I am going to attach a log file with complete reference.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
8 Replies 8
npchelpdesk
Visitor
I have the exact same issue with similar logs...
AIR-CTVM-K9 version 8.3.143.0
AP's: AIR-CAP1602I-A-K9
WiFi calling is critical in this facility (all using iPhones)...
Some Log Messages:
MESSAGE_RECEIVED
INVALID_RSN_IE
WLAN_SUPPORTS_STATIC_DYNAMIC_WEP
IP_ACQUIRED_AND_AUTH_NOT_REQ_OR_STATIC_DYNAMIC_WEP_SUPPORTED
CLIENT_MOVED_TO_ASSOCIATED_STATE
RECEIVED_INTERFACE_CHANGE
MESSAGE_RECEIVED
MESSAGE_RECEIVED
ASSOC_REQ_RECEIVED
MESSAGE_RECEIVED
MESSAGE_RECEIVED
ASSOC_REQ_RECEIVED
MESSAGE_RECEIVED
MESSAGE_RECEIVED
ASSOC_REQ_RECEIVED
MESSAGE_RECEIVED
MESSAGE_RECEIVED
WEB_AUTH_SUCCESS
MESSAGE_RECEIVED
INVALID_RSN_IE
MESSAGE_RECEIVED
Those were recorded during a 5 minute call which dropped a few times.  The caller was stationary at the time.
Can you perform:
  1. Debug client <mac address> for an affected phone during the roam drop
  2. show wlan <#> where # is the number of WLAN for voice so I can see the config.
What model phones are you using and what version of software?
Ric
Please rate helpful / correct posts
2 Files are attached...
The phone is an iPhone 10 with OS version 12.1.4.  However, we're having very similar issues with other iPhone's ranging from 5 - 10 and varying OS's.  82 total iPhones, all experiencing similar issues with dropped calls.  The WiFi signal appears to be great, then goes to nothing for a second or 2 then reconnects.   The troubles all seem very intermittent as well.
Thank you for any help you may be able to provide!
No issues with the debug but it shows the phone roaming 5 times to the same AP. I noticed your WLAN is 802.11g only, is that for a reason? You may find performance will improve if you make it dual band or 802.11a only.
For adaptive 802.11r please check the Over the DS is ticked below the Fast Transition option (under Layer 2 in the WLAN).
Or the following config will implement 5 GHz, over-the-ds adaptive .11r, and authentication key management (akm) for the wlan to assist with performance:
config wlan disable 12
config wlan radio 12 802.11ag
config wlan security wpa akm 802.1x enable
config wlan security ft over-the-ds enable
config wlan enable 12
Note: A brief outage will occur for above config to apply. Not saying this is a full fix but may assist..
Ric
Thank you very much.  Prior to seeing your update, we created a test ssid with some, if not all, of your recommendations.  Today we tested and still got several dropped calls, debug log seems to have lots of DHCP_REQD entries.  I'll post more info as to the results and configuration shortly.
Again, thanks for the help!
Config and Debug are attached.  The phone in use this time was an iPhone 7plus v12.1.4.  Many dropped calls throughout the test.
Did you ever get to the bottom of this? I am also having the same issue on iPhone 11 Pro with iOS 16.
