Showing results forĀ
Search instead forĀ
Did you mean:Ā
Please need help for upgrade ME 8.5.131 to ME 8.10.185 a
I have error wired0 stopped & wired0 started stuck and can't get ip
Please note can configure it full configuration but when get the ethernet cable off and On again it can't back to take ip
Rich R
Do a factory default reset of the AP using the button, then start again.
If you still see the error(s) attach the full console log from power-on here as a text file.
Do not paste hundreds of lines of logs into the thread.
State the model of AP you're working with.
New error
Duplicated configuration for "wired"
Ping on wlc & ap have 80% loss packet
Rich R
I make that and assign ip for CR and Ap the i import the bckp , but my issue after make full configuration and try to move the the ethernet cable to can plug it again, the device not take ip and makes the below
Waiting for ipv4 configuration
Duplicated configuration for wired
Wired0 started & stopped
So that what I faced
Thanks in advance
